P3135 - Airflow Control Valve: Exceeds Limit. (Solution)
Post01-02-2016, 18:04    Subject: P3135 - Airflow Control Valve: Exceeds Limit. Quote
Possible causes for P3135, Airflow Control Valve for Airflow Control: Lower limit not reached/Upper limit exceeded:
- Wiring/electrical connections to the suction nozzle valve(s) are faulty.
- Suction tube valve(s) defective
Possible solutions:
- Check the wiring/electrical connections to the suction nozzle valve(s).
- Replace suction tube valve(s).
Additional information for 3.0 V6 TDI engines: It is recommended to replace both intake valve covers at the same time. (Also check for error codes P1018, P2008 and P2011) icon_idea.gif
Ratings - P3135 - Airflow Control Valve: Exceeds Limit.
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error - Airflow control valve for 1.9 TDI BLS Diesel Engine Technology
No new posts Golf V Intake Manifold Flap - Airflow Control & P138 ... Diesel Engine Technology
No new posts Throttle valve 2 for 3.0 V6 TDI Diesel Engine Technology
No new posts BLS intake flap Upload
