Generatorfreilauf - Torx auf Generatorwelle rund gedreht | Posts 16+
Go to page: Previous  1, 2
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post27-01-2016, 15:01    Subject: Quote
Okay guys, thanks a lot!
I, in a moment of mental lapse, attached the impact wrench to the shaft instead of the free-running hub.
That explains a lot...
Big thanks!
Beste Grüße,
Hufe
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Autoservice likes this.
Post31-01-2016, 12:36    Subject: Quote
@ Herbert:
If something in my post is incorrect (thumbs down?), please comment on it with a factual statement so that everyone can learn from it! icon_rolleyes.gif
1.) It is correct that, like TE, the way this person "abused" the wave has caused a technical defect.
He probably even "screwed" with the internal Torx XZN 10 left-handed, and held the large one in place (meaning tightened, instead of loosened) icon_twisted.gif.
2.) A specialized tool should only be used for its intended purpose, and that does not include using an impact wrench.
But sometimes, there's just no other way.
Post02-02-2016, 14:40    Subject: Quote
I only use the impact wrench now because once, the shaft of the starter motor twisted around; the material used in the starter motors is far too soft.
Karma: +1344 / -0   Thank you, like it!
Post03-02-2016, 0:29    Subject: Quote
Using an impact wrench, you can also loosen screw connections on a freely rotating part (such as a screw on a rotor shaft), as long as...
- the applied moment is greater than the sum of the breakaway torque of the connection and the counter-torque of the rotor. The latter depends on the applied angular acceleration and the moment of inertia.
- ensuring that the working moment does not exceed the flow stress limit of the tool and the threaded connection;
Both can be safely achieved with a standard, non-oversized pneumatic impact wrench. You only need to turn the motor housing, not the rotor.
It becomes more difficult to tighten such a screw connection.
The torque wrench must be designed such that the difference between its torque and the opposing torque of the rotor corresponds to the tightening torque of the threaded connection. To achieve this, the torque wrench's limitation must be adjusted to match the rotor's moment of inertia (i.e.,). High-tech torque screwdrivers and calculations are used, or the nut is tightened with an unclear torque value.
Without it, a controlled suit can only be used with external support.
Otherwise, you'll end up paying for it later with a powerful impact wrench.
DieselBär30x likes this.
Post03-02-2016, 1:07    Subject: Quote
You can make an elephant out of a mosquito.
"Engage the clutch briefly 2 to 3 times (without the rotor spinning too much), and the job is done." You don't need to do a lot of calculations; you just need to use a bit of intuition.
Post03-02-2016, 1:13    Subject: Quote
And that's what you have in your toolbox. One man's trash is another man's treasure.
Sure, here's the translation:
"Best regards."
Post03-02-2016, 1:34    Subject: Quote
Gremlin
Avatar-Gremlin
Post03-02-2016, 6:27    Subject: Quote
Even though it's not relevant:
The vehicle is quite old, and it's uncertain whether it will survive the next generator replacement.
The recommended interval for replacing the slip rings on the T5 motor with AXE is 180,000 km; and in my case, I already had to replace them.
Re-centering the Lima on the console (on the T5) is a whole different story, and one that I don't want to get into... icon_twisted.gif
 Schleifring Lichtmaschine
 File size:  310.38 KB
 Viewed:  1575 times
No new posts Check Golf 4 VR 5 AGZ catalytic converter, engine running... Gasoline Engine Technology
