P2452 - Diesel Particulate Filter Pressure Sensor 'A', Malfunction (Solution)
Post03-02-2016, 12:31    Subject: P2452 - Diesel Particulate Filter Pressure Sensor 'A', Malfunction Quote
Error code P2452, Diesel particulate filter (DPF) pressure sensor 'A', the system output is set to a fault state when implausible readings are detected from the differential pressure sensor. To be checked:
- Wiring/electrical connectors for the differential pressure sensor.
- Incorrect connection or blockage of the differential pressure sensor on the diesel particulate filter.
- Differential pressure sensor is defective.
- Diesel particulate filter (DPF) malfunction (clogged or broken ceramic).
Ratings - P2452 - Diesel Particulate Filter Pressure Sensor 'A', Malfunction
No new posts P2453 - Diesel Particulate Filter Pressure Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0404 - Exhaust Gas Recirculation (EGR) Control Circuit M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2458 - Diesel Particulate Filter, Regeneration Duration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pressure Sensor BMM: Buy Now! Diesel Engine Technology
No new posts AGR Behavior in ALH 66kW Engines Diesel Engine Technology
No new posts GRA Behavior in ASZ (96 kW PD) - What's Normal? Transmission, Chassis, Body & Interior
No new posts STG - Drucksensor defekt? Diesel Engine Technology
