P0404 - Exhaust Gas Recirculation (EGR) Control Circuit Malfunction (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Post06-02-2016, 19:00    Subject: P0404 - Exhaust Gas Recirculation (EGR) Control Circuit Malfunction Quote
Error code P0404, Exhaust Gas Recirculation (EGR) control circuit, range/performance:
Possible symptoms:
- Power loss.
- Engine is noisy under load.
Possible causes:
- Wiring or connector to the AGR (Abgasrückführung) system is faulty (open circuit or short circuit), or the vacuum actuator on the AGR system is defective or not being properly controlled.
- Defective AGR module/AGR valve/throttle module.
- The EGR pipes and/or EGR cooler are clogged or leaking.
Solutions:
- Check the wiring and connectors, as well as the vacuum system, for the EGR valve control.
- Check the AGR module/AGR valve/throttle module.
- Inspect the EGR pipes and/or EGR cooler.
See also:
Ratings - P0404 - Exhaust Gas Recirculation (EGR) Control Circuit Malfunction
No new posts P2452 - Diesel Particulate Filter Pressure Sensor 'A', Ma... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P1405 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0400 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coolant Leak Sensor: Troubleshooting & Repair Diesel Engine Technology
No new posts Verhalten GRA bei ASZ (96 kW PD) - was ist normal? Transmission, Chassis, Body & Interior
No new posts AGR Behavior in ALH 66kW Engines Diesel Engine Technology
No new posts Strange behavior of the air conditioner Transmission, Chassis, Body & Interior
