georgmech Schrauber
Joined: 09/10/2009 Posts: 69 Karma: +8 / -0 Location: Langenrohr
24-02-2016, 19:02 Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment |
Hello, can anyone help me? I have a GOLF 5 1.4 BAD and I need to replace the crankshaft seal. Can I install the magnetic ring without special tools, and if so, how? Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Profile PM Email |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Dßsseldorf
25-02-2016, 12:44 Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment |
As far as I can tell, this won't work without special tools.
You need the "T10134" and the corresponding instructions for it. Everything else was a matter of chance.
I would try to borrow the tool from  . LG, Onkel BM
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Gremlin Schrauber
Joined: 08/18/2005 Posts: 396 Karma: +92 / -0 Location: Grainet 2000 Audi A4 Avant  Premium Support
25-02-2016, 14:38 Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment |
Hello Georg,
In this YouTube video, it is explained (Elring) how it is mounted.
Without that, it's not possible. What else might be needed, the measuring tool for the crankshaft belt pulley (to fix the OT point)?
What is not explained here:
the "Red" pin which is inserted just before assembly is for gasoline engines , the "black" is for diesel engines !
Profile PM Garage |
georgmech Schrauber
26-02-2016, 16:05 Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment |
It's getting stranger. If I disconnect the sensor, the engine runs perfectly normally. I borrowed the original VW tools and installed the ring according to the VW instructions. Since then, I've been getting intermittent error messages for the camshaft and crankshaft sensor, out of range. Motor was on OT and disconnected, it's like we say in Austria, "to be a fool" Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Profile PM Email |
26-02-2016, 17:03 Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment |
Quote: | | ....The engine was, however, on and disconnected |
Also, the correct marking spike should also be used with the special tool?
The fact that it operates with a defined input, likely stems from the fact that the NW (noise) signal is used as a substitute. LG, Onkel BM
