AFN läuft unrund | Posts 16+
Go to page: Previous  1, 2
dieselschrauber likes this.
Post20-04-2016, 17:12    Subject: Quote
dieselschrauber wrote:
Cylinder head with the strongest cylinder head gasket installed to minimize potential pressure increases in the combustion chamber due to the cylinder head overhaul.
It would not have been necessary, and in cases of significant thickness differences (e.g., from a single hole to a three-hole design), it could also cause side effects such as slightly reduced responsiveness.
Nevertheless: Congratulations! icon_wink.gif
Instead of that, a new set of connecting rod bearings would also have been beneficial given the mileage.
Translated on 26-07-2026, 6:58.
Post20-04-2016, 19:44    Subject: Quote
I did consider that, but I think that because the owner drives gently and I've been using this "miracle oil" every 15,000 km since 250,000 km, the bearing shells should still be in good condition.
It's not my car; I just keep it running for the neighbor, and there are certain limits to what I'm willing to do to maintain it.
During the engine overhaul, the first screws on the motor were left untightened, and even the clutch and dual-mass flywheel are still installed.
Translated on 26-07-2026, 6:59.
vwSchrauber
Post22-04-2016, 9:33    Subject: Quote
Instead of that, a new set of connecting rod bearings would also have been beneficial given the mileage....
Generally correct, however, it's not that simple to just "walk by" icon_confused.gif the 8D/8E models with their longitudinally mounted engine located above the front axle.
Translated on 26-07-2026, 7:00.
Post22-04-2016, 11:31    Subject: Quote
Basically correct, however, it's not that simple to just "go around" it with the 8D/8E models that have a longitudinally mounted engine over the front axle.
If the cylinder head icon_wink.gif is already removed, it shouldn't be much more difficult to lift the block accordingly... and the additional effort is minimal. .....but now it doesn't matter }.
Translated on 26-07-2026, 7:01.
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B6 2.5 TDI: Running Rough - Troubleshooting Diesel Engine Technology
No new posts 1.9 TDI (AWX) Audi A4 runs roughly when idling. Diesel Engine Technology
No new posts 1.4 TDI engine idling roughly Diesel Engine Technology
No new posts Idle running rough - faulty PCV valve? Gasoline Engine Technology
