servusssss Blaumann
Joined: 11/14/2006 Posts: 159 Karma: +12 / -0 Location: Vlbg
28-12-2014, 16:01 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
Hello fellow DIY enthusiasts,
Unfortunately, the support team couldn't find any errors.
It's an Audi A3 with a 1.6L 2V engine.
It has already been exchanged.
- Oxygen sensor after catalytic converter.
- Spark plugs
- Activated carbon filter.
- Temperature sensor checked.
- The intake and exhaust systems were checked multiple times for leaks.
- Emission levels are perfectly fine.
The exact error is:
Code: |
Adresse 01: Motorelektronik Labeldatei: RKS\06A-906-033-BGU.lbl
Steuergerâ°t-Teilenummer: 06A 906 033 EH
Bauteil und/oder Version: SIMOS71 1.6l 2V 9429
Codierung: 0000071
Betriebsnummer: WSC 06314 000 00000
VCID: 69DC1836401440562C3-803C
1 Fehler gefunden:
16804 - Katalysatorsystem; Bank 1
P0420 - 006 - Wirkung zu gering - Sporadisch
Freeze Frame:
Drehzahl: 3808 /min
Hex Wert: 0x0079
Geschwindigkeit: 120.6 km/h
Temperatur: 624.0°C
Drehzahl: 3808 /min
Hex Wert: 0x007C
Temperatur: 616.0°C
Unfortunately, the error is not consistent but occurs sporadically. There is no correlation with external temperature or other factors.
The solutions I found using "google" didn't necessarily help me much.
Has anyone else experienced this error?
Thank you very much for your efforts!
P.S.: I'm not really an expert on gasoline/petrol.
Translated on 23-07-2026, 12:09.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: NĂ€he DĂŒsseldorf
29-12-2014, 12:41 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
Quote: | | Unfortunately, the error is not constant but sporadic. |
When and how often does the error occur? What is the mileage?
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 23-07-2026, 12:11.
servusssss Blaumann
29-12-2014, 17:54 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
The error occurs every 200-400 kilometers after being cleared.
The car has 135,000 kilometers on the odometer, but it's not driven for short distances.
SG Christian.
Translated on 23-07-2026, 12:12.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
02-01-2015, 22:08 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
Check the lambda value after the catalytic converter while driving; it might indicate that the catalytic converter is not functioning correctly anymore.
NA,Gehörlose wie ich können auch Schrauben! Ihr HĂRT ich FĂHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 23-07-2026, 12:13.
Profile PM Email Garage |
servusssss Blaumann
05-01-2015, 11:45 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
I've already checked the values, but unfortunately, no error occurred during these trips.
I've now completed the readiness assessment.
The result is that a new error has been introduced.
Code: | 18628 - Bank 1 Sonde 1
P2196 - 006 - Signal zu fett
Freeze Frame:
Drehzahl: 1984 /min
(keine Einheit): 0.99
Spannung: 2.040 V
Spannung: 0.780 V
Readiness: 0010 1101 |
What do you think, probe or catalytic converter?
What else can be checked?
Sure, here's the translation:
"SG" can have different meanings depending on the context. It could stand for "Spielgemeinschaft," which is a German term for a sports club or association that combines players from multiple teams or organizations. Alternatively, it could refer to "SĂ€kularkantor," a type of church musician who does not hold religious beliefs. Finally, "SG" might be an abbreviation for "Sonstige," meaning "other" or "miscellaneous."
Translated on 23-07-2026, 12:14.
Joined: 04/12/2002 Posts: 18130 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
05-01-2015, 11:54 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
T3Surfer wrote: | | Check the Lambda value after the catalytic converter while driving. |
servusssss wrote: | | I've already looked at the values, but unfortunately, no error occurred during these trips. |
You should look at the lambda value in the measurement block and see if it's running too fat.
It doesn't matter if an error is accidentally entered while you're looking at it.
Translated on 23-07-2026, 12:15.
Profile PM WWW Garage |
servusssss Blaumann
05-01-2015, 12:18 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
Hi.
Quote: | | You should look at the lambda value in the measurement block and see if the engine is running too rich. |
I already checked the values during the ride, and I didn't notice anything unusual or any error messages.
This occurred during the readiness test.
I looked at the documents with identification numbers MWB 001-031-037; are these the correct ones?
Translated on 23-07-2026, 12:16.
05-01-2015, 12:28 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
Okay, just create a log file and upload it here.
Translated on 23-07-2026, 12:17.
Bertil Profi-Schrauber
05-01-2015, 12:36 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
"For vehicles with higher mileage, a P0420 code usually indicates an issue with the catalytic converter or the upstream oxygen sensor, assuming everything else is in good working order."
Here's an explanation of how you can get to the bottom of the problem.
It is important to consider both lambda sensors simultaneously. The error may not be registered immediately, but it can be easily identified by observing the trend of the lambda sensor voltage over time.
GruĂ Bertil
Translated on 23-07-2026, 12:18.
servusssss Blaumann
05-01-2015, 14:41 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
Here's another log, unfortunately with a lot of partial load data.
I can't see anything, but I know very little about the Lambda regulations.
| Description: |
 Download |
| File name: |
LOG-01-001-031-037.CSV |
| File size: |
8.29 KB |
| Downloaded: |
589 times |
Translated on 23-07-2026, 12:19.
05-01-2015, 18:51 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
It actually looks quite good, and the adjustments are also fine.
It looks like an intermittent problem.
| Description: |
| Lambdaregelung mit KDataScope visualisiert. |
| File size: |
57.16 KB |
| Viewed: |
5664 times |
Translated on 23-07-2026, 12:20.
servusssss Blaumann
dieselschrauber likes this. |
23-05-2016, 15:09 Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue |
Hello everyone,
After a brief inquiry via private message, here is the unfortunately not very pleasant solution to the problem.
After replacing the catalytic converter, there was a period of calm. However, after about 3000 km, the problem reappeared.
The car was then sold to a dealer.
In summary, the error could not be resolved.  Under the table, a new software solution for the MSG was recommended.
Translated on 23-07-2026, 12:21.
