Lupo GTi: LWR Connection Errors - Troubleshooting
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
georgmech
Post07-06-2016, 15:34    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
I'm having problems with a Lupo AVY, manufactured in 2000, where the headlight leveling system (LWR) is not working.
If someone sits in the trunk with the ignition off, the headlights will go down, but they will only adjust back up again when I turn off the ignition, remove the weight from the trunk, and then turn the ignition back on.
"Does anyone have any ideas? I also can't access the control unit; it always says 'too many connection problems with the control unit'."
Wir sind eine Werkstatt in Langenrohr bei Tulln und kÀmpfen tÀglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 05-09-2026, 5:38.
Back to top Profile PM Email
Post07-06-2016, 15:58    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Hello Georg,
Please provide an OBD scan of the vehicle.
georgmech
Post07-06-2016, 17:10    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Tuesday, June 7, 2016, 17:43:02:44616
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x64.
VCDS Version: RKS 15.7.4.1
Data as of: 20160226
Vehicle Identification Number: WVWZZZ6EZ1W002***
License plate: *******
Mileage: 136,630 km. Repair order: **** *****
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 6E (6X - VW Lupo (1998 > 2006))
Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
Vehicle Identification Number: WVWZZZ6EZ1W002368
Mileage: 136,630 km
Address 01: Engine Control Unit
Label file: DRV\036-906-033-AVY.lbl
Part number: 036 906 033.
Component: 1.6l/4V SIMOS3 00HS3551
Coding: 00031
Operating number: WSC 01286
VCID: 4E9535048A796D4EBC-513C
WVWZZZ6EZ1W002368 VWZ1Z0Y0761820
3 error codes found:
17978 - Engine control unit locked.
P1570 - 35-10 - - Intermittent.
16686 - Cylinder 2.
P0302 - 35-10 - Misfire detected - Intermittent.
16885 - Vehicle speed signal.
P0501 - 35-00 - Implausible signal.
Readiness: 0000 0000
Address 03: Brake Electronics
Label file: DRV\1J0-907-37x-ESP-F.lbl
Part number: 1C0 907 379.
Component: ESP 20 CAN V005
Encoding: 10755
Operating number: WSC 00370
VCID: 67DBE0A005C39C06DF-4B18
No error codes found.
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 6E0 909 605.
Part: 02 AIRBAG VW5 0005
Encoding: 12338
VCID: 68D9E39C08DD937ED6-4B18
Address 17: Control panel module
Label file: DRV\6X0-920-xxx-17.lbl
Part number: 6E0 920 800 B
Component: COMBINATION INSTRUMENT BOO V07
Coding: 00140
Operating number: WSC 00304
VCID: 2049BBBCA06DAB3E5E-515A
"One error found:"
01039 - Coolant temperature sensor (G2).
30-10 - Interruption / Short circuit after positive voltage - Occasional.
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway <-> CAN.
Encoding: 00022
VCID: 70E98BFC300D5BBE8E-515A
Address 25: Immobilizer
Label file: DRV\6X0-953-257.lbl
Part number: 6X0 953 257.
Component: IMMO 0007
Encoding: 00001
Operating number: WSC 00000
VCID: 7DF7A2C8775F26D615-4B00
Address 35: Central Locking
Label file: DRV\1C0-962-258-II.lbl
Part number: 1C0 962 258 N
Component: 1N Central Locking System 0001
Encoding: 00257
VCID: 326D41F4FE8129AEB8-4B7C
Address 45: Interior Monitoring. Label file: DRV\6Q0-951-171.lbl.
Part number: 6N0 951 171 C
Component: Interior monitoring. 0003.
VCID: 2F6B4880EDB30446D7-5196
"One error found:"
01463 - Alarm triggered by sensor for anti-theft system.
35-10 - - - Sporadically
Address 55: Headlight range control. Label file:
VCID: 55A7DA68ACAF1E967D-51B2
Note: Too many communication errors.
End----------------------------(Duration: 03:31)-----------------------------
Translated on 05-09-2026, 5:49.
dieselschrauber likes this.
Post07-06-2016, 17:36    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Was the light turned on during the diagnostic attempt? Older generations of LWR control units can often only be read out when the light is on.
Translated on 05-09-2026, 5:59.
Post07-06-2016, 17:49    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Check what bitrate VCDS briefly displays in the ECU information section (top left) when establishing a connection to the engine control unit. The protocol should be KWP1281.
Bitrate values are approximately 9600 or 10400 bits per second.
I'm not sure how the LWR (Low Voltage Release) is connected. VCDS tried connecting it via CAN, but if it doesn't work through the K-line, that's not surprising.
Is it possible to establish a direct connection to the LWR (multiple attempts), and if so, with which protocol and bitrate?
That leaves us with potentially corroded connectors, cables, or the LWR control unit itself.
georgmech
Post07-06-2016, 18:41    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Thank you very much for the prompt reply, I'll get started on it tomorrow.
Translated on 05-09-2026, 6:00.
Post07-06-2016, 22:31    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Um, does the LUPO have icon_eek.gif xenon headlights? Because you wrote that when the trunk is loaded, the lights move downwards. Doesn't it have the low beam range adjuster next to the light switch, next to the dashboard dimmer?
I have never actually read or attempted to read a manual LRW (Longitudinal Relaxation Waveform) before.
Most often, the fuse, the actuator motor, or (less frequently) the automatic headlight range adjuster itself is defective. Sometimes, the automatic headlight range adjuster motors become stuck due to lack of use; in such cases, tapping on the motor housing may help.
Translated on 05-09-2026, 6:01.
Post07-06-2016, 23:24    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Translated on 05-09-2026, 6:02.
Hojo-Hörnchen
Post08-06-2016, 7:59    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Try an older version of VCDS, such as 10.6 or 12.x. I had the same problem where version 15.x no longer allowed access.
Access is still possible even when the burners are switched off. However, actuator diagnostics will not be available in this case.
Seat Ibiza 6L Cupra TDI.
BUK und GUC. 136.000 Km.
georgmech
Post09-06-2016, 14:54    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Unfortunately, there's still no solution. Whenever I change the position of the LWR sensor with the lights on and then unplug and replug the connector, it will briefly adjust to the correct position, but then it stays there until I unplug and replug it again. It's driving me crazy.
Translated on 05-09-2026, 6:03.
Post09-06-2016, 16:00    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
It sounds like the LWR control unit is crashing after a short period of time and no longer responding to anything, neither changes to the sensor nor diagnostic messages.
Check what bitrate VCDS briefly displays in the control unit information in the top left corner when establishing a connection to the engine control unit. The protocol should be KWP1281.
Values for the bitrate are approximately 9600 or 10400 bits/s.
Please don't forget and post the displayed values...
Translated on 05-09-2026, 6:04.
vag-driver
Post15-06-2016, 8:09    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Apply contact cleaner to the connectors. It can't hurt and might help.
VG
Andreas.
Translated on 05-09-2026, 6:05.
bloesch
Post16-06-2016, 3:51    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
Hi there,
Aside from the communication problems...
Does the Lupo already have a dynamic LWR (adaptive damper)?
I suspect that the Lupo has a }static} LWR (Low Beam Range) system, which, in my opinion, only reacts once after "ignition on"...
Translated on 05-09-2026, 6:06.
vag-driver
Post16-06-2016, 5:45    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
I only know of two types. Either you have a control knob in the dashboard that allows you to manually adjust the beam range, or there isn't one, and the corresponding sensors in the suspension system handle it automatically.
Since the Lupo is not exactly new, I suspect the beam intensity is manually adjusted.
VG
Andreas.
Post16-06-2016, 6:14    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
No, nothing in the Lupo GTI is manually controlled. It has xenon headlights, which automatically include automatic low beam activation, and that's not even something being discussed here.
My former Golf IV also had xenon headlights. From what I could tell (PLEASE NOTE: this is just an observation, not based on knowledge), when you first turned on the lights, the headlights would activate, and then they would remain on. There was no active roll stabilization or anything like that, and the aLWR (adaptive lighting) was far too slow for that. In the control unit, you could see the sensors for both axles, and you could observe changes when the car moved. However, this didn't affect the functionality of the headlights.
Therefore, as Bloesch already mentioned, it is likely a static LWR.
Translated on 05-09-2026, 6:08.
Hojo-Hörnchen
Post16-06-2016, 14:56    Subject: Lupo GTi: LWR Connection Errors - Troubleshooting Quote
According to parts catalogs, the Lupo and the Seat Ibiza 6L have the same sensor with the same part number.
This means that the ALWR is static and re-calibrates at regular intervals, but not with every bump, acceleration, or deceleration.
It's working exactly as matthiasTDI96 described.
Has the user ever tried a different version of VCDS?
Translated on 05-09-2026, 6:09.
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop Action: Software Adjustment, Gearbox, 3L Lupo Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza LWR: Too many connection errors Electrical Systems, Vehicle Electronics, Multimedia
This topic is locked, you cannot edit or reply. STG Comfort Issues: Communication Problems Solved On-Board Diagnostics (OBD)
No new posts Differential Pressure Sensor: How Many Ports? Diesel Engine Technology
This topic is locked, you cannot edit or reply. How many PD elements are replaced after idle mode regulat... Diesel Engine Technology
