VW Polo 6R: Climate Control Disinfection
Glatze
Post31-05-2016, 16:08    Subject: VW Polo 6R: Climate Control Disinfection Quote
Hello.
How do I disinfect the atomizer with foam? Does anyone know if there's a hole where I can spray it through?
Because the spray is for the footwell area, it won't address the underlying cause, right?
Translated on 30-09-2026, 10:04.
vag-driver
Post01-06-2016, 14:01    Subject: VW Polo 6R: Climate Disinfection Quote
best regards
Why not? In an enclosed environment, the aerosol can work effectively and spread everywhere. Which spray are you referring to?
Translated on 30-09-2026, 10:05.
Glatze
Post01-06-2016, 14:04    Subject: VW Polo 6R: Climate Control Disinfection Quote
but does it also kill the bacteria on the vaporizer?
Translated on 30-09-2026, 10:06.
vag-driver
Post01-06-2016, 14:20    Subject: VW Polo 6R: Climate Control Disinfection Quote
It should. After all, it's a disinfectant. For example, Makra Cool Breeze.
Glatze
Post01-06-2016, 15:43    Subject: VW Polo 6R: Climate Control Disinfection Quote
ok danke
I had already considered using foam and distributing it through the pollen filter inlet in the system.
Basti1605
Post24-06-2016, 17:30    Subject: VW Polo 6R: Climate Control Disinfection Quote
We use Liqui Moly disinfectant in our company, along with the appropriate pressure lance. The best way to apply it is directly to the evaporator through the interior filter, if possible.
Here's a link to what I'm referring to. It's a symbolic representation of the Polo.
http://www.liqui-moly.de/liquimoly/mediendb.nsf/gfx/med_DOMB-79ZKMA_526CDC/$file/VW%20Polo%209N%20facelift.pdf
Hmm, the link to click directly isn't working. Sorry.
Translated on 30-09-2026, 10:07.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Disinfection: Why It's Not Working! Transmission, Chassis, Body & Interior
No new posts Best Climate: Tips & Solutions Transmission, Chassis, Body & Interior
No new posts Climate Control A4 Malfunction? Transmission, Chassis, Body & Interior
No new posts 1.9 TD Diava with Climate Control Transmission, Chassis, Body & Interior
