Mazda Performance Issues: Air Temp Sensor Problems
robs
Post09-10-2003, 14:00    Subject: Mazda Performance Issues: Air Temp Sensor Problems Quote
Hello to all forum readers,
After replacing the mass airflow sensor (MAF) in my Mazda 626 diesel due to a loss of power, the problem of reduced power and increased fuel consumption persists, despite no error codes being displayed.
Now the vehicle is back in the workshop.
Just now, I received a call saying that the temperature sensor is defective and will be replaced.
I won't know for sure if this solves the problem until tomorrow, as the part still needs to be ordered.
Now, my question for the experts: Can a faulty temperature sensor explain a significant loss of power and increased diesel consumption?
If so, why? Unfortunately, I haven't been able to find much information about the exact function of the temperature sensor, although I suspect it's an air temperature sensor, because the cockpit display showing the cooling temperature has always worked fine.
THANK YOU for the explanation icon_redface.gif icon_idea.gif.
Robs.
Translated on 26-07-2026, 10:57.
robs
Post09-10-2003, 15:06    Subject: Mazda Performance Issues: Air Temp Sensor Problems Quote
Can anyone provide information?
I couldn't find any information about that in the search function.
'Thank you.'
Translated on 26-07-2026, 10:58.
Gremlin
Post09-10-2003, 15:22    Subject: Mazda Performance Issues: Troubleshooting Air Temp Problems Quote
Of course, that's possible. For example, some diesel engines from the Volkswagen Group use two sensors (one for the engine and one for the instrument cluster), but they are housed together in a single unit.
If the engine sensor only indicates a very low temperature, the engine is running rich and may be limited in power output. This means full load operation is not possible, but fuel consumption will be extremely high under partial load conditions.
'However, there are forum posts about that.'
CU Gremlin.
Translated on 26-07-2026, 11:00.
robs
Post09-10-2003, 15:26    Subject: Mazda Performance Issues: Air Temp Sensor Problems Quote
First of all, thank you.
Then I still have some hope.
Keep yourselves informed.
I haven't found any good results for the under-air temperature sensor. icon_redface.gif
No offense.
Best regards.
robs
Translated on 26-07-2026, 11:01.
Gremlin
Post09-10-2003, 15:31    Subject: Mazda Performance Issues: Air Temp Sensor Problems Quote
No, air conditioning isn't necessary... it can't possibly be cold enough in here.
But you'll find something about coolant temperature sensors.
CU Gremlin.
Translated on 26-07-2026, 11:02.
No new posts Octavia 1z 2.0 TDI BMM hat Leistungsverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM-Leistungsverlust-Mazda Diesel Engine Technology
No new posts G3 AFN Power Loss: Troubleshooting Guide Diesel Engine Technology
No new posts Performance loss and no one knows what to do On-Board Diagnostics (OBD)
No new posts Leistungsverlust im Audi 1Z; weiß nicht weiter Diesel Engine Technology
