chriskross wrote: |
| Hello, do you want a tuning? |
No, I want adjustments to the mapping for the EGR system and the turbocharger boost pressure. Furthermore, a slight increase in the fuel injection volume in the lower RPM range and above 4000 RPM might be considered, along with shifting the rev limiter to higher RPMs.
What I exactly want still needs to be discussed.
