Coolant Temperature Sensor Passat 35i - Technical Specifications
pausanias
Post11-10-2003, 20:55    Subject: Coolant Temperature Sensor Passat 35i - Technical Specifications Quote
I have a Passat TD 35 I, manufactured in 1992. My problem is that the temperature gauge shows a temperature that is much too low. Since both the sensor and the gauge are functioning, I would like to know the technical specifications of the system. The sensor has a resistance of approximately 1400 ohms at 12 degrees Celsius, and approximately 300 ohms at warm engine temperature. Is this normal? The gauge shows 70 degrees when the resistance is 100 ohms, and 105 degrees when the resistance is 65 ohms. Who knows more?
Furthermore, the fuel gauge displays far too much (but the problem is not the voltage stabilizer, which provides approximately 10 volts).
joergs
Post11-10-2003, 22:06    Subject: Coolant Temperature Sensor Passat 35i - Technical Specifications Translating...
[Translating...]60 grad: 600-700 ohm
70 grad: 400-500 ohm
80 grad: 290-380 ohm
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts VW 1.6 TDI CR Specs: New Model Technical Data Diesel Engine Technology
No new posts Technical specifications ARL engine, 150 hp Diesel Engine Technology
No new posts Kühlmitteltemperaturgeber? Diesel Engine Technology
No new posts Coolant temperature sensor Audi 100 C4 AAT Diesel Engine Technology
