joe Guest
09-10-2003, 8:43 Subject: Injector Replacement: Audi A3 1.9 TDI Tips |
The needle lift sensor on my son's Audi 80 TDI 1Z is broken. We found a used one that supposedly works. What should be considered when replacing it? Is a new gasket recommended, or is it mandatory? What torque should be used for the screw?
Thank you for the answers!
Translated on 18-08-2026, 20:12.
Weini Guest
09-10-2003, 8:56 Subject: Injector Replacement: Audi A3 1.9 TDI Tips |
The tightening torque is 20 Nm. The copper gasket must be replaced at the same time (it only costs a few cents).
It's best to replace the hoses from the return line of the nozzles at the same time (they are often brittle and tend to leak after being disconnected and reconnected).
It should all be done in about 20 minutes - have fun!
Weini
Translated on 18-08-2026, 20:13.
Arne Guest
09-10-2003, 9:20 Subject: Injector Replacement: Audi A3 1.9 TDI Tips |
I think Ulf might have had something in his nozzles that caused them to be slightly misaligned when tightened, which made the engine sound a bit rougher. Take another look at Ulf's article about it – I think it contains all the information about replacing the nozzles.
arne
Translated on 18-08-2026, 20:14.
09-10-2003, 15:33 Subject: Injector Replacement: Audi A3 1.9 TDI Tips |
Arne wrote: | | I think Ulf might have had something in his nozzles that, when tightened, caused them to be misaligned, which made the engine sound a bit rougher. Take another look at Ulf's article about it - I think it also contains everything else about changing the nozzles. |
The story about the altered engine noise is presented in its own separate short article.
Otherwise, please refer to the articles on jet replacement tuning, as Arne already mentioned. Gruß Ulf
Translated on 18-08-2026, 20:15.
Profile PM Garage |
Gremlin Guest
09-10-2003, 19:52 Subject: Injector Replacement: Audi A3 1.9 TDI Tips |
By the way, that beautiful metallic clicking sound (like a hammer on an anvil) from the NBF nozzle disappeared for me after about 300 km...
It seems like they're giving these things away at every concert.
CU Gremlin.
Translated on 18-08-2026, 20:16.
joe Guest
10-10-2003, 7:16 Subject: Injector Replacement: Audi A3 1.9 TDI Tips |
Thank you for the tips, I'll get started now.
Translated on 18-08-2026, 20:17.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
11-10-2003, 22:21 Subject: Injector Replacement: Audi A3 1.9 TDI Tips |
and above all, pay attention to meticulous cleanliness  . ____________
Kein Auto mehr!
