TDI Exhaust Cooler: VW PD BLS DPF with Vacuum Valve
Post20-09-2016, 14:51    Subject: TDI Exhaust Cooler: VW PD BLS DPF with Vacuum Valve Quote
VW Golf 2009, 1.9 PD DPF, engine code BLS, 230,000 km.
It's only about the exhaust gas cooler, not the EGR system!
What effects can a faulty pressure sensor/stuck shaft and/or valve in the exhaust gas recirculation cooler (not the EGR valve) have on the engine during operation?
There are no error entries.
Sure, I will provide only the translation.
'Übersetze folgenden Text von Deutsch nach Englisch. Gib NUR die Übersetzung aus, keine Erklärungen.'
'Please translate the following text from German to English. Provide ONLY the translation, no explanations.'
Translated on 05-10-2026, 13:21.
Post20-09-2016, 16:13    Subject: TDI Exhaust Cooler: VW PD BLS DPF with Vacuum Valve Quote
Depending on the operating conditions, the required exhaust gas recirculation rate may not be achieved, which could prevent the Readiness Code (System Self-Test) from completing successfully in the long term.
Furthermore, the engine warms up more slowly without the EGR cooling system. icon_idea.gif
Translated on 05-10-2026, 13:22.
No new posts Vacuum Can Replacement: How-To Guide Upload
No new posts Turbo Vacuum Sensor Problems: Troubleshooting Guide Diesel Engine Technology
No new posts Vacuum sensor for VTG conversion. Diesel Engine Technology
No new posts Large vacuum chamber - when will it be in production? Diesel Engine Technology
