Opel Meriva 1.4 gasoline engine (Z14XEL) doesn't start when cold
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
georgmech
Post04-10-2016, 16:07    Subject: Opel Meriva 1.4 gasoline engine (Z14XEL) doesn't start when cold Quote
Here's a Opel Meriva with a Z14XEL engine. It only starts after multiple attempts if it has been sitting for a few hours. If it sits overnight, you have to crank it for about 10 minutes before it will start. The error memory is clear, the fuel pressure is good at the injectors, the throttle body has already been cleaned and recalibrated, and the thermostat sensor has also been replaced. Any ideas?
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 13-07-2026, 0:29.
Back to top Profile PM Email
Post04-10-2016, 17:11    Subject: Opel Meriva 1.4 gasoline engine (Z14XEL) doesn't start when cold Quote
Translated on 13-07-2026, 0:30.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts div. Golf 1J TDI and Gasoline, gradual loss of power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Opel turbodiesel engine (Isuzu) starts poorly when cold Diesel Engine Technology
No new posts TDI engine doesn't start when cold Diesel Engine Technology
No new posts Ford C-Max: Cold Start Problems & Fixes Diesel Engine Technology
No new posts Auxiliary Heater Not Starting Cold VW T4 (2000) On-Board Diagnostics (OBD)
