Service Intervall zurück setzen bei UDS | Posts 16+
Go to page: Previous  1, 2
vag-driver
Post16-11-2016, 9:08    Subject: Quote
Hello Benno,
What method are you using to try to reset the service?
What message do you receive when you use the "Reset Service" assistant?
Andreas
Translated on 26-08-2026, 15:08.
Post16-11-2016, 10:00    Subject: Quote
current software 16.8.2
Currently, it is 16.8.3 icon_cool.gif.
Benno
Post16-11-2016, 11:22    Subject: Quote
I just installed the latest software version 16.8.3 and reset it again. There is no change compared to the previous software. I have tried all the options, including fixed, flexible, and service reset. In each case, the only thing that remains is the display in the speedometer showing "Service due."
Benno.
Translated on 26-08-2026, 15:09.
Post16-11-2016, 12:09    Subject: Quote
Benno wrote:
I have just installed the latest software version 16.8.3 and reset it again. There is no change compared to the previous software. I have tried all the options with fixed, flexible, and service reset. In each case, the only thing that remains is the display in the speedometer showing "- Service due -".
Benno
Speak...
1.) Set the service type (flexible or fixed) or ideally leave it as it is from the factory.
2.) Configure the channels correctly and completely, as vag-driver described.
vag-driver wrote:
In short, here's the procedure for setting the parameters:
1. WIV time since inspection.
2. WIV travel distance after inspection.
3. WIV oil quality > good oil quality.
Possibly add more...
4. Fixed mileage since the last inspection based on operating hours: 0 km.
5. FIX: Time since last time-based inspection: 0 d
3.) Exit the control unit, turn off the ignition.
Screenshots will follow once I can find them. If anyone can post screenshots of the combination instrument customization channels in UDS, they will be gratefully accepted!
Translated on 26-08-2026, 15:11.
Benno
dieselschrauber likes this.
Post17-11-2016, 14:02    Subject: Bug Found: Troubleshooting and Solutions Quote
I have just reset the service indicator.
The small program for resetting everything was configured correctly, except for one point: the time since the last service. In my case, the dashboard still showed the old value, which was 400 days. After I manually set it to 0, the service reminder disappeared. So, the question is: is this a bug in the program, was it intentionally designed this way, is my dashboard not compatible with this program, or am I just too stupid to understand it?
Benno.
Translated on 26-08-2026, 15:14.
Post17-11-2016, 15:05    Subject: Quote
Hi Benno,
Thank you for the feedback! No, that is not intentional. Do you have a full diagnostic scan of the vehicle?
EDIT: See also https://community.dieselschrauber.org/en/viewtopic.php?t=28677#234425
Translated on 26-08-2026, 15:15.
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Service Interval Display / Maintenance Indicator Technical Data
No new posts CNG service reset, gas tank Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts vag-com and service interval indicator Diesel Engine Technology
This topic is locked, you cannot edit or reply. Resetting the service interval on an Audi A3 8P On-Board Diagnostics (OBD)
No new posts Porsche PoCOM Service Intervals On-Board Diagnostics (OBD)
No new posts Regarding the variable service interval again Diesel Engine Technology
