PD-Long-term experiences?
Post13-10-2003, 12:29    Subject: PD-Long-term experiences? Quote
Before I travel, possibly on or around October 17th, I wanted to ask if anyone here has experience with PD (port fuel injection) engines that have been running for a long time (ideally over 100,000 km). Specifically, I'm interested in whether the fuel injection system, along with its components, is prone to "predictable problems" – for example, similar to the nozzle wear seen in VP 37 engines.
@Jan6KViewing profile: Jan6K:
Does the current state of your defect statistics say anything about it?
@emilViewing profile: emil:
Your issues with the PD elements from the PD Ruckel thread are at least known to me, so you don't need to post everything again here icon_wink.gif
Bye for now
Julian
Post13-10-2003, 12:48    Subject: PD-Long-term experiences? Quote
Golf4 from a good friend of mine:
AJM from '99 (one of the first AJMs after the cylinder block coating disaster), now with 145,000 km, chip installed since 2000 with 140PS/408Nm.
Problems: 0
Repairs: 0 (Clutch replaced around 130,000 km)
Jan6K
Avatar-Jan6K
Post13-10-2003, 19:31    Subject: PD-Long-term experiences? Quote
Hi Ulf,
Regarding statistics:
So far, the latest post only contains one or two new data entries, so I haven't created a new version yet - therefore, the latest version is still current.
Jan
1Z5 CFHF / AHB H4D
michi3
Post13-10-2003, 21:22    Subject: PD-Long-term experiences? Quote
Passat with AJM
I bought it again in October 1999.
Installation of an additional control unit from PSI (ATU) with 136 hp and 340 Nm at 40,000 km.
Now, the odometer shows approximately 100,000 km. So far, there have been no mechanical issues, except for the LMM (likely referring to a lambda sensor) which needed to be replaced once.
For this, the torsion bars and suspension were replaced at around 90,000 km, as they had broken and worn out. Overall, I am satisfied.
Drehmoment statt Drehzahl
No new posts VW T6 TDI after 200,000 km, Long-term review Dieselschrauber Bar
No new posts Long-term consumption display has changed On-Board Diagnostics (OBD)
No new posts [Poll] OT: Experiences with eBay Transmission, Chassis, Body & Interior
No new posts RNS 510 Reviews: Your Experiences? Transmission, Chassis, Body & Interior
