For a long time, I've been struggling with my car due to its lack of power, or rather, its lack of agility. I first noticed the problem at the beginning of last winter (as far as I can remember, shortly after the timing belt was replaced and the winter tires were installed
Here's the translation:
"This manifests itself as follows: the acceleration is sluggish, and the maximum speed is reached slowly, but eventually reaches around 180 km/h (according to the speedometer). There's a noticeable lack of power, especially in 4th and 5th gear. When I fully accelerate at 100 km/h (5th gear, approximately 2200 RPM), not much happens. Subjectively, I would say that the engine starts pulling reasonably well, or even better, from around 3000 RPM."
"I'm hearing a faint noise (a hissing or sucking sound, it's hard to describe) somewhere between 1400 and 3000 RPM. The Bosch technician noticed it too. He said (before the dyno test) that the car was missing about 10 horsepower. So, it's probably not just my imagination."
At Bosch, all possible values were read out, and according to them, everything was okay. Well, that doesn't necessarily mean anything.
The Hard Facts:
- Power test bench -> 70kW. According to Bosch, everything should be fine. However, I don't know...
how the exact curve should look across the entire speed range.
- LMM temporarily replaced; no change.
- Replaced the pressure hose leading to the cooling system due to damage from rodent bites, tightened all hose clamps -> problem solved.
- Have the start of the injection process checked at least 2 times -> ok.
- AGR -> The hose was disconnected, but there was no improvement. In fact, there might have been a slight worsening. The sealing plates have already been ordered
just to be on the safe side.
Okay, I've been playing around with VAG-Com and logged the following:
Mass Air Flow Barometric Pressure Manifold Pressure Throttle Specified MAP Actual MAP Duty cycle
text
Regulator
valve?
mg/R mbar mbar % /min mbar mbar %
498.8 958.8 1030.2 15.3 1575 1795.2 1173 35.1
821.3 958.8 1723.8 100 2121 1866.6 1948.2 39.8
814.6 958.8 1927.8 100 2646 1836 1866.6 64.5
804.7 958.8 1846.2 100 3087 1825.8 1836 68.5
761.4 958.8 1815.6 100 3465 1825.8 1825.8 68.5
741.5 958.8 1825.8 100 3780 1805.4 1805.4 68.9
714.9 958.8 1795.2 100 3990 1795.2 1795.2 68.9
I hope this is somewhat legible...
I hope I will be helped here
