Sporadic PDC issues
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Basti1605
Post08-12-2016, 17:19    Subject: Sporadic PDC issues Quote
Hello colleagues,
We received an Audi A5 with rear-end damage at our workshop. Everything has been renewed, including two PDC (Parking Distance Control) sensors.
Okay, here's the translation:
Now, here's the case:
The customer is reporting that a sensor located at the back of the display has a red bar that extends to the edge (essentially, an obstruction right at the bumper).
However, that's not the case. I recently used the listening method and discovered that all the sensors in the rear are emitting an audible ticking sound, but one sensor in the front is defective. You can see an impact directly in the center of the sensor.
What's very strange to me is that I can't access the SG from the PDC. It seems like there isn't one there. But the PDC is doing its job, aside from occasional outages.
Do you have any other suggestions for me about what else I can do?
Log-WAUZZZ8TXCA042252-115780km Audi A5 PDC sporadische Fehlfunktion.txt
 Sporadic PDC issues
Sporadic PDC issues
 File name:  Log-WAUZZZ8TXCA042252-115780km Audi A5 PDC sporadische Fehlfunktion.txt
 File size:  13.17 KB
 Downloaded:  590 times
VCDS Support im Raum Hannover & Hildesheim
Post08-12-2016, 21:30    Subject: Sporadic PDC issues Quote
In older vehicles, the PDC (Parking Distance Control) control unit can be found under control unit addresses 10 or 72.
In newer cars, it is integrated into the body control module (module address 9).
You should be able to find it in the measurement data blocks.
PS: My last faulty PDC sensor looked fine from the outside, but the sealing compound had let water in. It initially only worked intermittently, especially in humid weather, and then stopped working altogether.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post12-12-2016, 8:19    Subject: Sporadic PDC issues Quote
Only paint PDC sensors once, if possible.
The second coat of paint causes similar symptoms.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Automatic: Intermittent Idle Surge Issues On-Board Diagnostics (OBD)
No new posts TDI Engine: Intermittent RPM Fluctuations BLS 77kW Diesel Engine Technology
No new posts Golf III TD: Intermittent Starting Problems Diesel Engine Technology
No new posts Sporadic emergency mode SEAT Leon On-Board Diagnostics (OBD)
