fouzek
10-12-2016, 21:18 Subject: WFS Login Code Missing: What to Do? |
I would like to pair two new, standard (non-radio) keys that I purchased from VW today. I initially thought that it might be possible with VCDS. However, as I've now read, it's definitely not possible without a WFS login code. Unfortunately, I didn't receive the key tag with the PIN from the previous owner, and it no longer exists (the owner before the previous owner had the car converted from standard keys to radio keys).
So, I'm now forced to have the keys programmed at VW, which will cost around 50-100 euros (conflicting information), right?
Or can I ask VW to read out the 4-digit code for me free of charge and tell it to me? According to my understanding, I am entitled to this code because I am the owner of the vehicle. It has essentially just been "lost."
If they refuse to cooperate, I'll just end up paying that exorbitant amount of money, and at that point, surely I'll have the "right" to know that 4-digit code, right?
How does VW log in, exactly? Using a 7-digit code? Is that some kind of "universal" PIN that allows VW to access any VAG vehicle?
Sure, here's the translation:
"I would be grateful for any tips or comments you may have."
Best regards, Daniel.
Translated on 17-09-2026, 1:48.
chli1976 Profi-Schrauber
11-12-2016, 8:41 Subject: WFS Login Code Missing: What to Do? |
First, it would be helpful to have data from the vehicle (a vehicle scan).
At VW, they are also unable to retrieve the login code. It is stored in a database and associated with the vehicle's chassis number and immobilizer ID.
There is only a 4-digit login code. The 7-digit code is derived from the 4-digit code and includes the date, importer number, and dealer number, and is only valid for one day (it can be bypassed using VCDS). Previously, the 7-digit code could be obtained via fax request, but this is no longer possible.
Assuming we know what type of vehicle it is, there are also other possible solutions.
VCDS
Translated on 17-09-2026, 1:50.
11-12-2016, 8:59 Subject: WFS Login Code Missing: What to Do? |
VW cannot retrieve or provide the login information, as they themselves do not have access to it.
Officially, only VW can program the keys for you. But, as chli already mentioned, with the right hardware/software (not VCDS), it's also possible to do it without VW, you just need to find someone who can.
Translated on 17-09-2026, 1:51.
Profile PM Garage |
fouzek
11-12-2016, 11:36 Subject: WFS Login Code Missing: What to Do? |
chli1976 wrote: | This is stored in a database and can be accessed here using the vehicle identification number (VIN) and the immobilizer ID.
Where is this database located? What's the point if, apparently, even VW can't access it, or who, then, "actually benefits" from this database?
TDI-GTI-4-Motion wrote: |
If VW itself doesn't have access, then they must be using this specific hardware/software (not VCDS), right?
Here's my car scan, and thanks for your help so far...
| Description: |
| File size: |
30.29 KB |
| Viewed: |
12224 times |
Translated on 17-09-2026, 1:52.
11-12-2016, 18:35 Subject: WFS Login Code Missing: What to Do? |
The VW tester connects to this database via the intranet and retrieves the necessary data.
There are two ways to access the login system. Either through the engine control unit (ECU). This would require a BDM tool or something similar.
Or, translate the instrument cluster.
It would also be interesting to know the year of manufacture. As far as I believe, it's relatively inexpensive (interface + software) up to around 2007.
VCDS
Translated on 17-09-2026, 1:53.
fouzek
12-12-2016, 13:25 Subject: WFS Login Code Missing: What to Do? |
The year of manufacture is either 1998 or 1999, so you're saying it's "relatively cheap (interface + software)," right? What is the name of this interface and software?
What is a BDM? (Google and searching here in the forum didn't yield any results...)
Is it relatively easy for a layman like me to figure out the login process using this Interface+ software, or does it require a significant amount of (VCDS) background knowledge / practical experience with VCDS?
I'd prefer to do it myself to learn, but I might need a step-by-step guide if it's not something that's easy to do on your own.
Thank you.
Translated on 17-09-2026, 1:55.
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
klahaui likes this. |
12-12-2016, 15:00 Subject: WFS Login Code Missing: What to Do? |
That:
http://maltchev.com/kiti/
It is possible to at least read out the login information from the Temic device.
Costs approximately €350.
Translated on 17-09-2026, 1:56.
