VCDS/VAG-COM: Adjusting Xenon Headlights
Marco
Post04-11-2003, 20:04    Subject: VCDS/VAG-COM: Adjusting Xenon Headlights Quote
Hello fellow enthusiasts,
How do I reset the automatic headlight range adjustment (LWR) on my A4 using VCDS? I want to adjust my headlights properly, but the left one is too high and the right one is too low.
After that, the new values also need to be saved somehow. Unfortunately, I couldn't find anything about that, and I didn't want to just start experimenting.
Translated on 24-09-2026, 21:58.
Michael II
Post04-11-2003, 20:41    Subject: VCDS/VAG-COM: Adjusting Xenon Headlights Quote
Hello Marco,
Shake the vehicle vigorously (move the shock absorbers up and down several times and allow the vehicle to settle). Then, for example, on a Golf 4, access control unit address 29.
Then, perform the initial configuration for ad group 001.
After the headlights have retracted to their basic position, ...
one can now (if necessary) adjust them mechanically.
After that:
Perform the initial setup for ad group 002.
System reset, baseline learned.
appear.
The control unit has now learned this position as the reference setting. The error message in the fault memory ("Headlights not adjusted") will be cleared, and normal operation will resume.
Tschüss
Michael II
Translated on 24-09-2026, 21:59.
Marco
Post04-11-2003, 22:06    Subject: VCDS/VAG-COM: Adjusting Xenon Headlights Quote
Hi Michael II,
It worked. Thank you very much!
Translated on 24-09-2026, 22:01.
w123diesel
Karma: +7 / -1   Thank you, like it!
Post27-12-2003, 17:40    Subject: VCDS/VAG-COM: Adjusting Xenon Headlights Quote
Do the settings for the xenon headlights remain saved after a battery replacement or when disconnecting the battery for charging?
It would be a pain if you had to recalibrate this value every time you disconnect the battery.
"By the way, the xenon headlights were replaced twice because the VW mechanics probably used excessive force during the mechanical adjustment. Later, it turned out that the headlight control unit was defective and was not able to retain the learned settings."
That cost VW over €1000 in goodwill payments each time, and it wasted a lot of my time and caused me a lot of stress.
Jürgen.
Post27-12-2003, 18:29    Subject: VCDS/VAG-COM: Adjusting Xenon Headlights Quote
tja das Xenon leiden. Mein Golf hat da auch nur Pech mit. Habe da schon alles einmal wechseln lassen müssen, Steuergerät rechts jetzt schon das dritte mal. Wollte damals Xenon haben weil es ja auch so viele blinde Glühlampengölfe gibt und ein Argument für mich langjährige Wartungsfreiheit war. Naja It wasn't like that.
The basic settings made with VCDS are lost when the battery is disconnected. At least, that was the case for me.
Translated on 24-09-2026, 22:02.
Post23-08-2015, 20:51    Subject: VCDS/VAG-COM: Adjusting Xenon Headlights Quote
Update for newer vehicles, such as the Audi A5:
Context:
- Vehicle is parked on a level surface.
- Headlights, suspension components, etc. are fully assembled and functional.
- Control unit address 09: Central electronics/vehicle electrical system, no errors in the fault memory (exceptions: errors 01539, 02658, and 02659).
- Set the light switch to ON (NOT to Auto).
[Select control unit address]
[09 - Central electrical system/On-board network]
[Default setting - 04]
Group 011.
[Go!Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
The measurement value block displays: [Register Position | Learned Value | 0.0 | N/A].
Enable default settings.
[ON/OFF/Forward]
The measurement block displays [Setting | Headlight | Not available | N/A].
Now, adjust the headlights as desired.
Disable default settings.
[ON/OFF/Forward]
The measurement value block displays "[Reg. Position | Learned | 0.0 | N/A]" again.
[Ready, return]
Don't forget to clear the error memory!
[End connection, go back - 06]
Translated on 24-09-2026, 22:04.
A3-Besitzer
Registered VCDS User
Post14-12-2016, 20:55    Subject: VCDS/VAG-COM: Adjusting Xenon Headlights Quote
How can I adjust the settings using VCDS on an A3 8VA with DLWR?
Exactly?
Thank you for the information.
Translated on 24-09-2026, 22:07.
No new posts Error light, indication of defective lamps General Tips
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Xenon Headlights: Are They Blinding? Diesel Engine Technology
No new posts Grundeinstellung Xenon mit VCDS Audi A5 2014 On-Board Diagnostics (OBD)
No new posts TDI ALH: Can't Adjust Injection Timing with VCDS? Diesel Engine Technology
No new posts H7 Bulb Lifespan: How Long Do They Last? Diesel Engine Technology
