A6 4B Front Driveshaft, Driver Side
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Sashtheflash
Post06-01-2017, 16:23    Subject: A6 4B Front Driveshaft, Driver Side Quote
Hello everyone,
Ich fahre einen A6 4b 2.5tdi Quattro Ez 03/2002. MKB AKE 6. Gang switch.
Now, my front left driveshaft is making noises when accelerating or when turning.
Upon closer inspection, I saw that the boot on the front left side was completely torn. My car was briefly in the workshop with the request to replace the joint.
Call: The joint we ordered doesn't fit. I spent over an hour on the phone, and apparently there's only one left in all of Germany... but it costs 300€ just for the part.
Then I said, "Put the thing back together, I'll come and pick it up."
I just ordered this wave, which is currently on sale.
SKF VKJC 4879
According to the description, it should fit, right?
If not, then what else do I need?
Thank you very much in advance.
Translated on 16-10-2026, 14:22.
Post06-01-2017, 20:50    Subject: A6 4B Front Driveshaft, Driver Side Quote
Without wanting to offend you, the best way to find out if the ordered part fits is to ask the supplier. icon_idea.gif
Translated on 16-10-2026, 14:23.
Karma: +645 / -0   Thank you, like it!
Post08-01-2017, 16:04    Subject: A6 4B Front Driveshaft, Driver Side Quote
All the dimensions are listed here; please measure and compare them.
Spidan wrote:
Installation side: Front axle, left.
External gear, wheel side: 38.
Length: 632.6 mm
Number of teeth on ABS ring: 45.
Gear side joint diameter: 130 mm.
Drilling diameter: 10.5 mm.
Number of boreholes: 6.
Hole circle diameter: 114 mm.
Part No. Spidan: 21171
Translated on 16-10-2026, 14:24.
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Avoid squeaking windshield wipers at the front General Tips
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
No new posts Intermittent Driver Airbag Malfunction Transmission, Chassis, Body & Interior
No new posts Driver's side fender liner, 3BG model, year 2003 Upload
No new posts Audi A8: Driver Side Control Units Malfunction Electrical Systems, Vehicle Electronics, Multimedia
No new posts Is the driver's side window switch for the Beetle swapped? Transmission, Chassis, Body & Interior
