mfdk Guest
13-10-2003, 21:38 Subject: VAS 5051 Login: Passat AKN Diagnostics |
I am looking for the login code for my Passat, engine code AKN, manufactured in 2000.
If anyone can help me, I would appreciate the information.
mfdk
Translated on 27-08-2026, 20:05.
joergs Guest
13-10-2003, 21:45 Subject: VAS 5051 Login: Passat AKN Diagnostics |
What do you want to do?
mfdk Guest
14-10-2003, 10:35 Subject: VAS 5051 Login: Passat AKN Diagnostics |
I would like to increase the base value by 400 (if possible), following the schema described in several previous posts:
TDI tuning for all TDI engines except those with a 'Pumpe-Düse' (injection pump) system.
It is very important to save the old values beforehand.
for possible process reset.
01 Engine
Login ???
Channel 01 32784 Max Values (these are sliders that you can move up and down).
(can be pushed!)
Channel 02 33638 Max Values.
(Excerpt from an older post)
mfdk
Translated on 27-08-2026, 20:06.
joergs Guest
14-10-2003, 10:43 Subject: VAS 5051 Login: Passat AKN Diagnostics |
Are they not working?
Okay, I'm ready. Please provide the German text you want me to translate.
Translated on 27-08-2026, 20:07.
mfdk Guest
14-10-2003, 22:58 Subject: VAS 5051 Login: Passat AKN Diagnostics |
@joergs
Thank you for the information.
I entered the code 11463 and found that my control unit does not support this function.
Thank you.
mfdk
Translated on 27-08-2026, 20:08.
joergs Guest
14-10-2003, 23:08 Subject: VAS 5051 Login: Passat AKN Diagnostics |
@ joergs
Thank you.
mfdk
That shouldn't have been the right one for your issue, should it? It activates the gray setting, doesn't it?
Translated on 27-08-2026, 20:09.
