psand
19-01-2012, 16:40 Subject: Remote control for stand heater (Golf V) - programming |
I have the following problem: I would like to re-pair my original remote control with my original heater in my Golf V, manufactured in 11/2007.
The car was delivered with the built-in heating system and has been working perfectly so far. I have now replaced the battery in the remote control and also tried to program a second original remote control using VCDS. Unfortunately, it didn't work out, and now neither of them is working!
The search in the forum and on the web unfortunately did NOT yield a solution, as the descriptions with and without VCDS (which fuse needs to be pulled?) are very different or I simply didn't understand them - I'm not a VCDS professional!
{MARKER: Präzise, schrittweise Beschreibung}
Please send me a precise, step-by-step description for programming via VCDS or without VCDS by pulling the fuse. Disconnecting the battery is not an option, as it is securely mounted in the trunk.
Thank you for your help!
Best regards, Peter.
psand
24-01-2012, 22:42 Subject: Remote control for stand heater (Golf V) - programming |
Hello, can anyone help me? I'm unfortunately really stuck! Best regards, Peter.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
24-01-2012, 22:45 Subject: Remote control for stand heater (Golf V) - programming |
Hello Peter,
Please write me a PM tomorrow.
To know exactly what is installed in your vehicle, please post a vehicle scan.
Best regards, Rainer
Profile PM WWW Garage |
26-01-2012, 20:48 Subject: Remote control for stand heater (Golf V) - programming |
psand wrote: | Wednesday, January 11, 2012, 11:29:28:42031
VCDS Version: RKS 10.6.5
Data Status: 20110418
Vehicle Type: 1K0
Scan: 01 02 03 08 09 15 16 17 18 19 22 25 37 42 44 46 47 52 55 56
62 72 75 76 77
Vehicle Identification Number: WVWZZZ1KZ8W100000 Odometer: 48760 km
01-Motor -- Status: OK 0000
02-Gear -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering Angle Sensor -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Deck -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-piece instrument -- Status: OK 0000
18-Standheizung -- Status: OK 0000
19-CAN-Gateway -- Status: OK 0000
22-Allrad -- Status: OK 0000
25-Way Ignition Switch -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-door electric Driver -- Status: OK 0000
44-Control Aid -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-door electric Passenger. -- Status: OK 0000
55-Light fixture control -- Status: OK 0000
56-Radio -- Status: OK 0000
62-door electric hi. left -- Status: OK 0000
72-door electric high rear -- Status: OK 0000
75-Telematics -- Status: OK 0000
76-Parking Assist -- Status: OK 0000
77-Phone -- Status: OK 0000
Address 01: Motor Label file: RKS\022-906-032-BDB.lbl
Part Number SW: 022 906 032 KG HW: 022 906 032 GP
Part Number: R32-DQ-EU4 G 1067
Revision: 1QH02--- Serial Number: VWX7Z0GN3N6802
Encoding: 0000178
Operating number: WSC 01287 785 00200
VCID: 5A94C35BEC84
No errors found.
Readiness: 0110 1101
Address 02: Transmission Label File: RKS\02E-300-0xx.lbl
Part Number SW: 02E 300 011 CK HW: 02E 927 770 AD
Part Number: v0698X0502ea__ge082 1499
Revision: 05108020 Serial Number: 00001008030081
Encoding: 0000020
Plant No.: WSC 04940 001 00001
VCID: 5A94C35BEC84
No errors found.
Address 03: Brake Label File: 1K0-614-517-MK60-A.lbl
Part Number SW: 1K0 614 517 AD HW: 1K0 614 517 AD
Part Number: ESP 4MOTION MK60-AT 0102
Revision: 00H14001
Encoding: 0004744
VCID: 69F6EC9739E2
No errors found.
Address 08: Climate/Heating Label file: RKS\1K0-907-044.lbl
Part Number SW: 1K0 907 044 CS HW: 1K0 907 044 CS
Part: ClimatronicPQ35 130 1212
Revision: 00130022 Serial Number: 00000000000000
Operating Number: WSC 00000 000 00000
VCID: 7AD4A3DB4C44
No errors found.
Address 09: Bus Label File: RKS\3C0-937-049-30-H.lbl
Part Number SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Main Bus Junction Box H54 2202
Revision: 00H54000 Serial Number: 00000007809000
Encoding: E68F8F2701041500471400001400000000097B075C000100000000000000
VCID: 71C684F71132
Part Number: 1K1 955 119 E
Part Number: Wiper 131107 021 0501
Encoding: 00038805
Part Number: 1K0 955 559 AF
Part Number: RLS 181107 046 0204
Encoding: 00217165
No errors found.
Address 15: Airbag Label file: RKS\1K0-909-605.lbl
Part Number SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Part: 5G AIRBAG VW8R 034 8000
Revision: 05034000 Serial Number: 003B6D09YRU4
Encoding: 0013639
Operating number: WSC 01269 785 00200
VCID: 6CF895833610
No errors found.
Address 16: Steering Wheel Label File: RKS\1K0-953-549-MY8.lbl
Part Number SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Part Number: J0527 051 0100
Encoding: 0013122
VCID: 78D0B9D37248
Part Number: XXXXXXXXXXX
Part Number: E0221 002 0010
No errors found.
Address 17: Combination Instrument Label File: RKS\1K0-920-xxx-17.lbl
Part Number SW: 1K6 920 874 B HW: 1K6 920 874 B
Component: COMBINATION INSTRUMENT VDD 1216
Revision: V0002000 Serial Number: VWX7Z0GN3N6802
Encoding: 0007103
Operating number: WSC 73849 124 92177
VCID: 32444BFBD4B4
No errors found.
Address 18: Stand Heater Label File: RKS\1K0-815-007.lbl
Part Number: 1K0 815 007 BF
Part Number: Stand Heater 021 3803
Revision: 00021000 Serial Number: 09011559000000
Encoding: 0001112
VCID: 69F6EC9739E2
No errors found.
Address 19: CAN-Gateway Label file: RKS\1K0-907-530.lbl
Part Number SW: 1K0 907 530 L HW: 1K0 907 951
Part Number: J533__Gateway H15 0180
Revision: H15 Serial Number: 1400K07A3007D5
Encoding: ED837F0E700E020002
VCID: 304041F3DAB8
No errors found.
Address 22: Allrad Label file: RKS\1K0-907-554.lbl
Part Number: 1K0 907 554 L
Part Number: Haldex 4Motion 0116
Encoding: 0000001
VCID: 364C77EB38DC
No errors found.
Address 25: Ignition Lock Label File: RKS\1K0-920-xxx-25.lbl
Part Number: IMMO VDD 1216
VCID: 32444BFBD4B4
No errors found.
Address 37: Navigation (J0506) Label file: RKS\1T0-035-680.clb
Part Number SW: 1T0 035 680 B HW: 1T0 035 680 A
Part: RNS-MID H04 1100
Revision: AB001001 Serial Number: VWZ6Z7G5320066
Encoding: 060100000100001200
Operating number: WSC 01316 785 00200
ASAM Dataset: ------------------------- ------
VCID: 2D7E5887CD8A
No errors found.
Address 42: Electrical Door Driver Label File: RKS\1K0-959-701-MAX3.lbl
Part Number SW: 1K0 959 701 N HW: 1K0 959 701 N
Part: Door-SG 006 1203
Encoding: 0000182
VCID: 39567CD709C2
No errors found.
Address 44: Lenkhilfe Label file: RKS\1Kx-909-14x-44.clb
Part Number: 1K1 909 144 M
Part: EPS_ZFLS Class 141 H08 1901
VCID: 354E70E725DA
No errors found.
Address 46: Comfort System Label File: RKS\1K0-959-433-MAX.clb
Part Number SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Part: KSG PQ35 G2 020 0204
Revision: 00020000 Serial Number: 00000000000000
Encoding: 809002005103087F2D0484057008CFC6F0FC00
VCID: 832A5E3FBB8E
Part Number: 1K0 951 605 D
Part: LIN BACKUP HORN H07 9001
Part Number: 1K0 951 178 A
Part: Tilt Sensor 003 0203
Part: Interior Monitoring 003 0203
No errors found.
Address 47: Soundsystem Label file: RKS\3C0-035-456.lbl
Part Number SW: 1K6 035 456 C HW: 1K6 035 456 C
Component: 08K Audio Amplifier 0001
Revision: 00001000 Serial Number: 00000000167032
VCID: 2C785583F690
No errors found.
Address 52: Rear Passenger Door Electrical Label file: RKS\1K0-959-702-MAX3.lbl
Part Number SW: 1K0 959 702 N HW: 1K0 959 702 N
Part: Door-SG 006 1219
Encoding: 0000438
VCID: 3A5463DB0CC4
No errors found.
Address 55: Light fixture control. Label file: RKS\1T0-907-357.lbl
Part Number: 1T0 907 357
Part: Dynamic LWR 0003
Encoding: 0000004
VCID: F4C80DE3EE20
No errors found.
Address 56: Radio (J0506) Label file: RKS\1T0-035-680.clb
VCID: 2D7E5887CD8A
No errors found.
Address 62: Electrical door opener, left side. Label file: RKS\1K0-959-703-GEN3.lbl
Part Number SW: 1K0 959 703 K HW: 1K0 959 703 K
Part: Door-SG 006 1206
Encoding: 0000144
Operating number: WSC 01287 785 1012552
VCID: 385079D332C8
No errors found.
Address 72: Electrical door, right. Label file: RKS\1K0-959-704-GEN3.lbl
Part Number SW: 1K0 959 704 K HW: 1K0 959 704 K
Encoding: 0000144
VCID: 39567CD709C2
No errors found.
Address 75: Telematics Label file: None
Part Number: MFA XP
Component: MFA XP_F V2.09
Encoding: 0002624
VCID: 7CD8A5C34670
No errors found.
Address 76: Parking Assist Label File: RKS\1K0-919-283.lbl
Part Number: 1K0 919 283 A
Part: 22 Parking Assist 0101
VCID: 2D7E5887CD8A
No errors found.
Address 77: Telephone Label file: RKS\3C0-035-730.lbl
Part Number SW: 5N0 035 730 HW: 5N0 035 730
Part: Telephone 2510
Revision: 00011000 Serial Number: 0000000042262
Encoding: 0020145
VCID: E5EE60A755FA
No errors found.
Ende -------------------------------------------------------------------- |
26-01-2012, 21:23 Subject: Remote control for stand heater (Golf V) - programming |
I accidentally posted the wrong link earlier.
According to the part number and the label file used, it should work for you like this:
- Go to Control Unit 18 (auxiliary heating)
- Click the "Customize" button.
- In the adjustment channel 5, either enter "0" as the new value for radio receivers without sleep mode, or "1" for radio receivers with sleep mode.
If a value is already stored in the adjustment channel, save it again. What's inside you?
- Within 5 seconds, press the "OFF" button of the transmitter until the transmitter diode starts blinking.
Helpful would be, for example, a photo of the remote control you are using, as well as any data you know about the remote control for your space heater/remote.
psand
27-01-2012, 14:49 Subject: Remote control for stand heater (Golf V) - programming |
Hello Rainer,
Thank you, that's all. Everything worked perfectly! As always: Fast and competent assistance!
27-01-2012, 18:16 Subject: Remote control for stand heater (Golf V) - programming |
Yes, and what have you done now, or what value was in the adjustment channel?
psand
27-01-2012, 19:01 Subject: Remote control for stand heater (Golf V) - programming |
Exactly as you described! The value in Adjustment Channel 5 was 1. I removed it and then simply re-entered and saved it. Then it also worked with the "training" of the FFB.
27-01-2012, 19:08 Subject: Remote control for stand heater (Golf V) - programming |
Great, thanks for the feedback! I just guessed what it might be...
hkss Blaumann
Joined: 12/17/2006 Posts: 171 Karma: +13 / -0 Location: Karlsruhe 2017 Skoda Yeti Premium Support
17-01-2017, 20:30 Subject: Remote control for stand heater (Golf V) - programming |
dieselschrauber wrote: | Hello,
Best regards, Rainer |
My 2017 Skoda Yeti Diesel DSG was delivered last week without any fuel flow for the auxiliary heater (due to clogging during transport).
The reordered FFB has arrived, and the dealer has no time for "further repairs" for the next 2 days - I have an appointment on Monday and need to bring the car in for 2-3 hours. Hm.... actually, I would prefer to do it myself and save the time and effort involved in scheduling appointments and waiting for responses, etc.
But I already tried today. As described above, this is not possible.
| Description: |
 Download |
| File name: |
Log-KA-HK-TMBLD75L8H6000000-30km-Yeti-K-00a.txt |
| File size: |
14.41 KB |
| Downloaded: |
631 times |
Profile PM Garage |
17-01-2017, 22:18 Subject: Remote control for stand heater (Golf V) - programming |
Quote: | | As described above, this is not possible. |
why, which adjustment channels are displayed for the radiator control unit with you?
hkss Blaumann
17-01-2017, 22:33 Subject: Remote control for stand heater (Golf V) - programming |
dieselschrauber wrote: | Hi,
Uh... I don't quite remember it off the top of my head.
But it can be carried out exactly as described above.
Channel 5 was already selectable.
I have changed the 1 that was already there to 0 and then back to 1.
Then "Accept" clicked and also quickly on "OK" in the next window
then it will work, and then hold the OFF button on the FB until it blinks red.
But it didn't amount to anything. The space heater is not responding to the remote control.
When I pressed the "On" button, the green LED only blinked and nothing happened.
Profile PM Garage |
Bertil Profi-Schrauber
dieselschrauber likes this. |
18-01-2017, 8:36 Subject: Remote control for stand heater (Golf V) - programming |
Learning the FB (Engine Control Unit) can also be done without VCDS:
Programming the Webasto Thermo Top remote control -> Page 5
18-01-2017, 9:12 Subject: Remote control for stand heater (Golf V) - programming |
If the PDF moves...
Webasto wrote: | To set up the Telestart transmitter for Thermo Top E and C
1. Insert the battery into the battery compartment of the transmitter.
2. Remove the 1A (black) fuse from the heater fuse holder.
(Power interruption receiver)
3. Wait for at least 5 seconds and re-insert the fuse.
4. Within approximately 2 seconds, but no later than 6 seconds from the start, press the OFF button on the Sen-
hold for at least 1 second.
5. Training complete.
A maximum of 4 remote controls can be programmed at the same time.
In subsequent training sessions, the "oldest" sender will be deleted. |
and
Webasto wrote: | To set up the Telestart transmitter for Thermo Top Evo
As described above for Thermo Top E and C, but using either fuse 1A.
(black, vehicle interior) or remove fuse 30A (green, engine compartment)
(Power interruption receiver). |
hkss Blaumann
18-01-2017, 13:10 Subject: Remote control for stand heater (Golf V) - programming |
Profile PM Garage |
