Touran: Read DPF Ash Mass with VCDS (BLS)
Schmierpfote
Karma: +21 / -0   Thank you, like it!
Post29-01-2017, 20:55    Subject: Touran: Read DPF Ash Mass with VCDS (BLS) Quote
Hello forum members,
Today I cleared the DPF on my Touran at 291,636 km using VCDS. The loading coefficient was 27.6%, which went down to 0%. However, can anyone tell me how to read the ash mass using VCDS? Shouldn't the DPF be full at this mileage?
Thank you for your tips.
Wolfgang
Translated on 07-08-2026, 4:44.
Back to top Profile PM Email
chli1976
dieselschrauber likes this.
Post29-01-2017, 21:02    Subject: Touran: Read DPF Ash Mass with VCDS (BLS) Quote
MWB 69 and above.
VCDS
Translated on 07-08-2026, 4:45.
Schmierpfote
Post29-01-2017, 21:12    Subject: Touran: Read DPF Ash Mass with VCDS (BLS) Quote
Thank you very much, chli1976, for the quick response; I will check it out. Have a nice Sunday. Best regards, Wolfgang.
Wiesel
Post29-01-2017, 23:15    Subject: Touran: Read DPF Ash Mass with VCDS (BLS) Quote
My BLS (Basic Life Support) certifications are as follows:
Code:
                Adresse 01: Motorelektronik  (03G 906 056 )
12:51:17 Block 067: Partikelfilter (Abgaswerte I)
  24.0°C  Temperatur vor Abgasturbolader
  24.0°C  Temperatur im Partikelfilter
  0.00  Druckdifferenz Partikelfilter
  0.00  Offset Differenzdruck
12:51:23 Block 068: Partikelfilter (Abgaswerte II)
  0.0 %  Beladungs- koeffizient
  29.0  Aschemasse
  0.0 %  Aschelernwert
12:51:31 Block 069: Partikelfilter (Regenerationsstatus I)
  00000000  Status 1 Regeneration
  00000000  Binärwert
  00000000  Binärwert
  00000000  Status 4 Regeneration
12:51:38 Block 070: Partikelfilter (Regenerationsstatus II)
  0.0 s  Regenerations- zeit
  0.0  Erfolglose Regenerationen
  0.0  Erfolreiche Regenerationen
Micha
Schmierpfote
Post30-01-2017, 5:00    Subject: Touran: Read DPF Ash Mass with VCDS (BLS) Quote
Thank you, Micha, great template for me. Thanks, Wolfgang.
No new posts Forced DPF Regeneration: VAG TDI with VCDS Troubleshooting & Guides
No new posts Particulate Filter (DPF) VAG TDI Diesel Mass Balance, Max... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Read ash data On-Board Diagnostics (OBD)
No new posts Particulate filters frequently release material, with an ... Diesel Engine Technology
No new posts Read particulate filter loading status Diesel Engine Technology
No new posts Reading out a VW Touran - problems On-Board Diagnostics (OBD)
