Electric Thermostat Explained: Audi A4 8E
Karma: +591 / -0   Thank you, like it!
Post20-01-2017, 22:29    Subject: Electric Thermostat Explained: Audi A4 8E Quote
Hello!
Brauche mal eine techn. Sure, here is the translation of the text from German to English:
"Explanation."
My neighbor has an Audi A4, model 8E, manufactured in 2002, with a 2.0 gasoline engine. The engine code is ALT.
Has the electric radiator fan been running at high speed for 10 seconds after engine start (cold start) during the recent cold weather?
The car didn't reach its normal operating temperature, and the heating system wasn't producing properly hot air. The temperature gauge also wasn't displaying anything accurate.
Okay, so first I read all the error codes, and in the engine control unit, it showed an error for sensor G62, which is the dual coolant temperature sensor, indicating a short circuit to positive voltage, with an implausible signal that appears intermittently.
"Because it was the simplest and cheapest option, and there didn't appear to be anything obviously wrong with the wiring, I replaced the G 62."
The problem with the constantly running cooler fan has been fixed. The temperature display is working again as well. So far, so good.
I bought it at the icon_biggrin.gif, and I also looked at what else might be suitable at Edeka.
The problem with the excessively low coolant temperature persists.
As far as I understand, the car has an electric thermostat.
A single unit costs €95 net. It has a 2-pin connection for a cable.
Before I replace it just in case, I'd like to understand how it works first.
Is this a standard bimetallic thermostat, as has been common for about 70 years, but with just a temperature sensor inside?
Or, is it actually a fully electric one, with a servo motor?
I didn't even know something like that existed until today.
Translated on 26-07-2026, 14:22.
Post20-01-2017, 22:52    Subject: Electric Thermostat Explained: Audi A4 8E Quote
It's best to see it directly:
Translated on 26-07-2026, 14:24.
Post20-01-2017, 23:27    Subject: Electric Thermostat Explained: Audi A4 8E Quote
Hi!
Thank you, great.
I didn't know that kind of thing existed, especially with an old car like that.
Are there any experiences with that?
Should I just replace the part, or would it be more helpful to check other things first?
The icon_biggrin.gif told me, in any case, that they sell thermostats more often.
Translated on 26-07-2026, 14:25.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post21-01-2017, 19:12    Subject: Electric Thermostat Explained: Audi A4 8E Quote
Hello Steffen,
Machs neu, die Dinger sind wirklich anfällig, oft verziehen sich die Kunststoffteile im Inneren und auch das Gehäuse ganz leicht. DSometimes, that's enough.
that the function is limited and it no longer opens or closes properly.
The manufacturer for the original part (VW/AUDI: 06B121111K) is Behr/Mahle.
Behr also distributes this product in the aftermarket as well, but at a lower price icon_wink.gif.
The part number for the ALT is TM3100 from Behr.
Price-wise, it then comes to approximately €45 because it doesn't have the logo of the vehicle manufacturer on it. icon_biggrin.gif
Mpire
Translated on 26-07-2026, 14:27.
dieselschrauber likes this.
Post03-02-2017, 19:40    Subject: Electric Thermostat Explained: Audi A4 8E Quote
Hello!
I fixed the car today.
Everything is working again.
The neighbor bought the thermostat himself; it's a part from Mahle and cost around €40.
It was quite a job taking the intake manifold off, with all those strange clamps that I don't really have the right pliers for.
I think I should buy something for that too.
Well, anyway, we disassembled the defective thermostat to see exactly what was broken.
Okay, so it's a standard thermostat at first glance, and looking at the electrical components, it seems like there's an additional mechanism in one of the cylinders that adjusts the preload. So, something that expands and is electrically controlled is definitely included.
The cause of the failure was that the two plastic clips, made of cheap black plastic, which hold the thermostat in place, broke off. As a result, the thermostat was only loosely held within the housing.
Translated on 26-07-2026, 14:29.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 2.5 TDI error code "00575 intake manifold pressure" Diesel Engine Technology
No new posts Serpentine Belt Replacement Audi 100 - Emergency Fix Diesel Engine Technology
No new posts Audi 100 2.5 TDI, engine code ABP, issues after chip tuning Diesel Engine Technology
No new posts Audi A6 Battery Problem: Weak Battery Warning Light Electrical Systems, Vehicle Electronics, Multimedia
