Glühkerzen wechseln - Wahrscheinlichkeit des Reißens | Posts 16+
Go to page: Previous  1, 2
Post22-04-2017, 12:55    Subject: Quote
Spark plugs replaced, instructions: https://community.dieselschrauber.org/en/viewtopic.php?t=29019
Translated on 06-09-2026, 5:49.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post26-04-2017, 19:26    Subject: Quote
Great instructions!
I can only confirm that a warm engine is the most important factor in preventing glow plug failure.
"I tested this on my 2.5 V6 TDI AKE, which had new BAU cylinder heads installed at 260,000 km. After 120,000 km, the glow plugs needed to be replaced. They were very difficult to remove when cold. The threads of two of the glow plugs were rounded off on the outside!"
After that, the engine was warmed up to approximately 50 degrees Celsius. The other two glow plugs came out very easily.
Again, bring the engine temperature up to about 70 degrees Celsius, and the remaining glow plugs came out just as easily. The threads on the outside of the glow plugs were pointed. As mentioned, these were the original glow plugs installed from the factory in the new cylinder heads, so any contamination from ceramic paste or something similar from the previous installation can be ruled out.
Translated on 06-09-2026, 5:50.
Post26-04-2017, 20:18    Subject: Quote
Thank you icon_smile.gif.
Translated on 06-09-2026, 5:51.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Replacement 1.9 TDI AVF Diesel Engine Technology
No new posts Glow Plugs 1Z - Buy Online Now! Diesel Engine Technology
No new posts Glow Plug Replacement Audi A6 C4 AEL Diesel Engine Technology
No new posts Glow plugs for coolant Diesel Engine Technology
