Idle Speed Control Valve 38mm
Kammelot
Post15-05-2017, 19:59    Subject: Idle Speed Control Valve 38mm Quote
Hello everyone!
I read the idle speed control data from my T4 today.
Result:
Cylinder, size 0.75.
-0.28
3. 1.86
4. 0.02
-0.85
The compression values are the same except for one cylinder, which has a reading of 0.5 bar (approximately 29 bar when cold). The injectors have been recently rebuilt by Diesel Service using Bosch components.
The engine is running somewhat unevenly. The bus speed is approximately 2000 RPM and noticeable.
All filters are new. (It might not be related, but...) The mass airflow sensor is also new. The fuel pressure is dynamically adjusted. The valve timing is perfect. The camshaft looks great...
"You can't really hear anything about the hydraulic lifters. There's absolutely no noise during operation..."
Does anyone have any ideas?
Greetings to everyone.
Matthias.
Translated on 19-08-2026, 21:04.
Karma: +1344 / -0   Thank you, like it!
Post15-05-2017, 21:08    Subject: Idle Speed Control Valve 38mm Quote
Hi there,
The value of injector #3 is not good. If it's not the injector with the needle lift adjuster, swap it with one from another cylinder and see if the problem moves along with it.
Translated on 19-08-2026, 21:06.
Post15-05-2017, 22:05    Subject: Idle Speed Control Valve 38mm Quote
I would also like to swap the injectors from cylinder 1 and 3. It's possible to do, as the injector code (NHG) is either 4 or 5 depending on the engine type.
Translated on 19-08-2026, 21:07.
No new posts Idle speed control Diesel Engine Technology
No new posts AVF Idle Speed Control - Cylinder 3 On-Board Diagnostics (OBD)
No new posts Idling Oxygen Sensor: Causes of -2.4mg/H Reading Diesel Engine Technology
No new posts Idle speed control for the 2.5 TDI BDH engine Diesel Engine Technology
