Control Unit 8 Not Responding (Dashboard Removed)
stolley
Karma: +38 / -1   Thank you, like it!
Post15-06-2017, 5:00    Subject: Control Unit 8 Not Responding (Dashboard Removed) Quote
Hello everyone!
I just disassembled the control panel in my T5 to replace the actuator motor V159 (and while I'm at it, I'm also installing a reverse camera!).
My question to you now is:
I wanted to test the new actuator or perform the initial setup before assembly. However, when I connect VCDS and select the corresponding control unit, it doesn't respond. Could this be due to all the disassemblies?
Thank you and best regards.
Volker.
 File size:  2.56 MB
 Viewed:  2089 times
Translated on 07-09-2026, 12:51.
Post15-06-2017, 6:43    Subject: Control Unit 8 Not Responding (Dashboard Removed) Quote
Post15-06-2017, 8:59    Subject: Control Unit 8 Not Responding (Dashboard Removed) Translating...
[Translating...]
stolley
Post15-06-2017, 18:27    Subject: Control Unit 8 Not Responding (Dashboard Removed) Quote
TDI-GTI-4-Motion wrote:
Translated on 07-09-2026, 12:52.
No new posts Audi A2 Documentary: Engine Noises from Dashboard Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Dashboard Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Control Unit Not Responding: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts ABS Error: Control Unit Not Responding On-Board Diagnostics (OBD)
No new posts Audi Cabrio 89: Convertible Top Control Unit Not Responding On-Board Diagnostics (OBD)
No new posts 1Z No Response: Troubleshooting & Solutions On-Board Diagnostics (OBD)
