Polo 6R, 2010, DPF - Questions
alexandererlangen
Post23-06-2017, 11:55    Subject: Polo 6R, 2010, DPF - Questions Quote
My car has less power. That's why I started the DPF regeneration process several times in a row yesterday. Unfortunately, this also causes the filter to become clogged a little more each time. (according to IDE00433-ENG103279, Particle filter: oil ash volume-MASS_ASH_PF). Or how do you interpret these values?
Here's how I started the regeneration process:
Security Access
Enter code.
Then, to Channel.
and there, the option "IDE01637 - Service regeneration of particulate filter while driving" was selected.
clicked "New Value 00 00" and "Do It".
After reading the value, it displayed "00 01" and the light on the speedometer illuminated for about 10 minutes. Then, I repeatedly restarted the previous process.
But apparently, the DPF is no longer cleaning itself. Am I doing something wrong?
Address 01,03L 906 023 AH, channel IDE01637 - Service regeneration of particulate filter while driving, adapted from 00 00 to 00 00.
Address 01: Engine (03L 906 023 AH)
23:19:05
IDE00427-ENG101722 Particle filter: differential pressure - DIP_PF 9.62 hPa
IDE00428-ENG100917 Particle filter: offset for differential pressure - DIP_PF_AD[0] -1.00 hPa
IDE00430-ENG102682 Particle filter: field regeneration request status - STATE_RGN_PF 0.
IDE00431-ENG102952 Particle filter: field regeneration lock status - LV_STATE_TEST_RGN_PF_INH_HLD 00000000
IDE00432-ENG103847 Particle filter: time since last regeneration - T_WOUT_RGN 988.20 s
IDE00433-ENG103279 Particle filter: oil ash volume - MASS_ASH_PF 32.1282579 g
IDE00434-ENG102050 Particle filter: Soot mass calculated - MASS_SOOT_SIM_PF 6.16 g
IDE00435-ENG101197 Particle filter: Soot mass measured - MASS_SOOT_PHY_PF 2.82 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration - DIST_RGN 28.5 km
IDE01407-ENG100958 Particle filter: fuel consumption since last regeneration - FCO_SUM_RGN 2.28 l
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
23:33:20
IDE00427-ENG101722 Particle filter: differential pressure - DIP_PF 7.21 hPa
IDE00432-ENG103847 Particle filter: time since last regeneration - T_WOUT_RGN 220.00 s
IDE00433-ENG103279 Particle filter: oil ash volume - MASS_ASH_PF 32.1450481 g
IDE00434-ENG102050 Particle filter: Soot mass calculated - MASS_SOOT_SIM_PF 4.78 g
IDE00435-ENG101197 Particle filter: Soot mass measured - MASS_SOOT_PHY_PF -0.69 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration - DIST_RGN 6.7 km
IDE01407-ENG100958 Particle filter: Fuel consumption since last regeneration - FCO_SUM_RGN 0.48 l
23:46:33
IDE00427-ENG101722 Particle filter: differential pressure - DIP_PF 7.88 hPa
IDE00432-ENG103847 Particle filter: time since last regeneration - T_WOUT_RGN 245.30 s
IDE00433-ENG103279 Particle filter: oil ash volume - MASS_ASH_PF 32.1557863 g
IDE00434-ENG102050 Particle filter: Soot mass calculated - MASS_SOOT_SIM_PF 4.84 g
IDE00435-ENG101197 Particle filter: Soot mass measured - MASS_SOOT_PHY_PF -1.02 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration - DIST_RGN 6.6 km
IDE01407-ENG100958 Particle filter: fuel consumption since last regeneration - FCO_SUM_RGN 0.53 l
00:01:14
IDE00427-ENG101722 Particle filter: differential pressure - DIP_PF 6.47 hPa
IDE00432-ENG103847 Particle filter: time since last regeneration - T_WOUT_RGN 337.50 s
IDE00433-ENG103279 Particle filter: oil ash volume - MASS_ASH_PF 32.1664339 g
IDE00434-ENG102050 Particle filter: Soot mass calculated - MASS_SOOT_SIM_PF 5.58 g
IDE00435-ENG101197 Particle filter: Soot mass measured - MASS_SOOT_PHY_PF -1.14 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration - DIST_RGN 8.8 km
00:12:48
IDE00427-ENG101722 Particle filter: differential pressure - DIP_PF 7.96 hPa
IDE00432-ENG103847 Particle filter: time since last regeneration - T_WOUT_RGN 92.70 s
IDE00433-ENG103279 Particle filter: oil ash volume - MASS_ASH_PF 32.1743511 g
IDE00434-ENG102050 Particle filter: Soot mass calculated - MASS_SOOT_SIM_PF 4.94 g
IDE00435-ENG101197 Particle filter: Soot mass measured - MASS_SOOT_PHY_PF -1.20 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration - DIST_RGN 1.2 km
IDE01407-ENG100958 Particle filter: Fuel consumption since last regeneration - FCO_SUM_RGN 0.04 l
00:24:19
IDE00427-ENG101722 Particle filter: differential pressure - DIP_PF 6.88 hPa
IDE00432-ENG103847 Particle filter: time since last regeneration - T_WOUT_RGN 138.00 s
IDE00433-ENG103279 Particle filter: oil ash volume - MASS_ASH_PF 32.1828600 g
IDE00434-ENG102050 Particle filter: Soot mass calculated - MASS_SOOT_SIM_PF 4.30 g
IDE00435-ENG101197 Particle filter: Soot mass measured - MASS_SOOT_PHY_PF -1.49 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration - DIST_RGN 3.2 km
IDE01407-ENG100958 Particle filter: Fuel consumption since last regeneration - FCO_SUM_RGN 0.12 l
00:41:05
IDE00427-ENG101722 Particle filter: differential pressure - DIP_PF 6.30 hPa
IDE00432-ENG103847 Particle filter: time since last regeneration - T_WOUT_RGN 361.20 s
IDE00433-ENG103279 Particle filter: oil ash volume - MASS_ASH_PF 32.1935982 g
IDE00434-ENG102050 Particle filter: Soot mass calculated - MASS_SOOT_SIM_PF 6.04 g
IDE00435-ENG101197 Particle filter: Soot mass measured - MASS_SOOT_PHY_PF -0.49 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration - DIST_RGN 3.8 km
IDE01407-ENG100958 Particle filter: fuel consumption since last regeneration - FCO_SUM_RGN 0.23 l
Schöne Grüße
Alexander
dieselschrauber likes this.
Post23-06-2017, 14:33    Subject: Polo 6R, 2010, DPF - Questions Quote
Regeneration reduces the amount of soot in the DPF and increases the amount of oil ash (which is the non-combustible portion of the soot).
In your case, the ash content increases in the parts-per-thousand range, and the soot load is minimal.
The differential pressure can only be evaluated if the flow rate is known.
If you're experiencing a loss of power, you might want to investigate other areas (boost pressure, airflow, EGR valve, fuel rail pressure).
alexandererlangen
Post23-06-2017, 15:49    Subject: Polo 6R, 2010, DPF - Questions Quote
Hello Herbert,
Thank you for your reply.
If the amount of oil ash becomes too large, does that mean a new DPF (Diesel Particulate Filter) is needed? When would that be the case for that car?
And what does it mean that the calculated and measured values of "soot mass" differ so significantly?
Interestingly, the DPF warning light has never illuminated for me while driving. Does it only come on when you force it to activate? Was it correct to simply set the value to 0 to enforce this?
Is the value IDE01407-ENG100958, "Particle filter: fuel consumption since last regeneration" (FCO_SUM_RGN), very accurate because it calculates the amount of burned oil based on the exhaust gases, or is it rather inaccurate?
I also want to learn a lot along the way, even though I'm going to exclude the DPF now. The ride was definitely faster after that, but probably because the exhaust gas recirculation system is turned off during the regeneration process?
Schöne Grüße
Alexander
Post25-06-2017, 16:12    Subject: Polo 6R, 2010, DPF - Questions Quote
Hi Alexander,
If the amount of oil ash becomes too large, does a new DPF need to be installed? When would that be the case with that car?
If your car is still relatively new, this shouldn't be an issue yet, but replacing a new DPF can be very expensive, or you can have it cleaned, or:
/viewtopic.php?t=24243&highlight=dpf+clean
Depending on fuel/oil consumption and the operating materials used, beyond 200,000 km:
Okay, I'm ready. Please provide the German text you want me to translate.
and
The more ash in the DPF, the higher the differential pressure values. IMHO, the DPF is not the problem in your case. To get a feel for differential pressures, see:
Forcing a regeneration of the DPF can be beneficial in certain operating conditions, such as when not primarily used for very short trips, and can be a worthwhile practice in many cases. One option would be to expand the DPF for cleaning, but I wouldn't recommend doing that yet.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Noises & Sounds - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Polo 1.6 TDI DSG: Power Loss Troubleshooting On-Board Diagnostics (OBD)
No new posts A few questions (I'm a diesel newbie) Questions about que... Diesel Engine Technology
No new posts LMM & Boost Gauge: Common Questions Answered Diesel Engine Technology
No new posts AFS for 3C: Questions and Answers On-Board Diagnostics (OBD)
