Oversteering Issues: 3C5 CBAB Model Analysis
findus170
Post30-08-2017, 21:21    Subject: Oversteering Issues: 3C5 CBAB Model Analysis Quote
Here's the customer's complaint (which I haven't been able to reproduce myself yet): In the 3C5 model, very rarely when overtaking (in 4th gear), the power cuts out. After that, you can shift to a lower gear, and the problem disappears.
The car was driven with a warm engine and the tank was well-filled. It has the CBAB 140 HP common rail engine with the NOx update. The turbocharger pressure sensor and the exhaust temperature sensor (G235) were replaced a few months ago. The diesel filter is approximately 10,000 km old. The error memory is also clear, showing no faults.
Does anyone have any ideas what might be causing this, or what else I should check?
Thank you and best regards.
Simon.
Wednesday, August 30, 2017, 19:39:15:46228
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 7 x64.
VCDS Version: RKS 17.1.2.0
Data as of: 20170131 DS267.1
Vehicle Identification Number: WVWZZZ3CZAE108986
License plate:
Vehicle type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62
69 72 77
Mileage: 218,790 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel Steering Electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
77-Phone -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die Bäume, und die Blätter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Control Module (CBA)
Label file: DRV\03L-906-022-CBA.clb
Part number SW: 03L 906 019 AC, HW: 03L 907 309 F.
Part: R4 2.0l TDI G000SG 9977
Revision: 22H25--- Serial Number: VWZCZ000000000
Encoding: 0000072
Operating number: WSC 40089 002 1048576
VCID: 6CD3B6124F3F63212F-8038
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics
Label file: DRV\3C0-614-109-C4.clb
Part number SW: 3C0 614 109 AH, HW: 3C0 614 109 AH.
Component: J104 C4 440 V2 0024
Revision: --025--- Serial Number: 00000104040078
Encoding: 0033275
Operating number: WSC 05311 000 00000
VCID: 64C3DE32A7EF2B6167-8030
Address 08: Climate Control/Heater (J255)
Label file: DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 BT, Part number HW: 5K0 907 044 BT.
Component: Climatronic
Part number: H15 0709
Revision: 00003001
Encoding: 0000000003
Operating number: WSC 05311 115 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 7EF78C5AE143E1B191-802A
Address 09: Central Electronics
Label file: DRV\3C0-937-049-30-H.lbl
Part number SW: 3C8 937 049 AB Hardware number: 3C8 937 049 AB
Component: On-board network module H57 3204.
Revision: 00H57000 Serial Number: 00000003531598
Encoding: E5988F0700041A00470A00000F00000000015D435C000120000308000000
Operating number: WSC 05124 000 00000
VCID: 71EDA766681D8EC91C-8024
Subsystem 1 - Part number: 3C1 955 419 B
Label file: DRV\1KX-955-119.CLB
Component: Wiper 260110 006 0208
Encoding: 00046997
Subsystem 2 - Part number: 1K0 955 559 AH
Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 060210 054 0403
Encoding: 00208936
Address 10: Parking Assist 2 (J446)
Label file: DRV\3C8-919-475.clb
Part number SW: 3C8 919 475 A, HW: 3C8 919 475.
Part: PARKING ASSIST 8K H07 0009
Revision: -------- Serial Number: 08741003110013
Encoding: 110002
Operating number: WSC 05314 000 00000
VCID: 326F686A6D9BF5D125-8066
Address 15: Airbag
Label file: DRV\5N0-959-655.lbl
Part number SW: 5N0 959 655 H, HW: 5N0 959 655 H.
Part: J234__03H VW10 HI 1916
Revision: 20013000 Serial Number: 003E1P20Q6RI
Encoding: 0013128
VCID: 428F38AA1D3B4551B5-8016
Subsystem 1 - Serial number: 6332MTS663440060.
Subsystem 2 - Serial number: 6342MTS635690080.
Subsystem 3 - Serial number: 6351HTS6BDTT76KJ
Subsystem 4 - Serial number: 6361HTS6DTG386KJ
Subsystem 5 - Serial number: 0000000000000000
Subsystem 6 - Serial number: 0000000000000000
Address 16: Steering wheel electronics (J527)
Label file: DRV\3C0-953-569.clb
Part number SW: 3C9 953 501 BN, HW: 5K0 953 569 AB.
Component: STEERING MODULE 009 0122
Revision: FF010035 Serial number: 20100205200272
Encoding: 118A270002
ASAM Dataset: EV_VW360SteerWheelUDS A03002
ROD: EV_VW360SteerWheelUDS.rod
VCID: 76E7947AC973A9F1C9-8022
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 3C8 959 537 D, HW: 3C8 959 537 D, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-TK6 H06 0022
Encoding: E20000
Address 17: Control panel module (J285)
Label file: DRV\3C8-920-xxx-17.clb
Part number SW: 3C0 920 872 G, HW: 3C0 920 872 G.
Component: KOMBI H03 0305
Encoding: 161F00
Operating number: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 295D8F06484DB60994-807C
Address 19: Diagnostic interface
Label file: DRV\3C0-907-530-V3.clb
Part number SW: 3C0 907 530 N, HW: 3C0 907 951.
Component: J533, Gateway, H14 0172.
Revision: H14 Serial Number: 1021G101300465
Encoding: F9A07F46400603042002
VCID: 2C5376128FBFA3216F-8078
Address 25: Immobilizer
Label file: DRV\3C0-959-433-25.clb
Part number SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial Number: VWZCZ000000000
Operating number: WSC 131071 1023 2097151
VCID: 7AFF804A356BCD91AD-802E
Subsystem 1 - Part number: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 37: Navigation (J0506)
Label file: DRV\1T0-035-680.clb
Part number SW: 1T0 035 680 C, HW: 1T0 035 680 C.
Component: RNS-MID H04 2680
Revision: AB001001 Serial Number: VWZ6Z7K9034155
Encoding: 060004020400008000
VCID: 2E577C1A79A3D13141-807A
Address 42: Door Electric Driver (J386)
Label file: DRV\3C0-959-70X-GEN4.clb
Part number SW: 3C0 959 701, HW: 3C0 959 793.
Component: DOOR-SG FT 002 0305
Revision: 13101005 Serial number: 0000401059
Encoding: 0200FD
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 65C5C33664D5526970-8030
Slave Driver:
Subsystem 1 - Part number SW: 3C0 959 703 HW: 3C0 959 795 Label file: DRV\1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001271097
Encoding: 0000D0
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 K, HW: 5N1 909 148 G.
Component: J500__APA-BS, Class 147, 0703.
Revision: 1AH03726 Serial Number: 00093250033602
Coding: 0000258
VCID: 3A7F404A75EB0D91ED-806E
Address 46: Comfort System
Label file: DRV\3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0612
Encoding: 0091020051030E763004941570084F0E707C01
Subsystem 1 - Part number: 1K8 951 605.
Component: LIN BACKUP HORN H09 9002.
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE, not mounted.
Address 4F: Central Electricity II (J520)
Label file: DRV\1K0-907-532.clb
Part number SW: 1K0 907 532, HW: 3C0 907 951.
Component: EZE_2 H14 0172
Revision: -------- Serial Number: 1021G101300465
Encoding: 00000000
VCID: 66C7C43A91D3597179-8032
Address 52: Door electric, passenger side (J387) Label file: DRV\3C0-959-70X-GEN4.clb
Part number SW: 3C0 959 702, HW: 3C0 959 792.
Component: DOOR-SG BT 002 0305
Revision: 15101005 Serial number: 0000413161
Encoding: 0200FC
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 66C7C43A99D3597179-8032
Slave Passenger:
Subsystem 1 - Part number SW: 3C0 959 704 HW: 3C0 959 794 Label file: DRV\1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001279097
Encoding: 0000D0
Address 53: Parking brake
Label file: DRV\5N0-907-801.clb
Part number SW: 3C8 907 801 E HW: 3C8 907 801 E
Part number: J540 EPB3 VW-15417 0007.
Revision: 010 Serial Number: 00000000160818
Coding: 0000056
Address 56: Radio (J0506) Label file: DRV\1T0-035-680.clb
Address 61: Battery Management (J840)
Label file: DRV\1K0-907-534.clb
Part number SW: 1K0 907 534, HW: 3C0 907 951.
Component: Battery control unit H14 0172.
Encoding: 030B085A
VCID: 68DBCA029BC74F014B-803C
Subsystem 1 - Part number SW: 1K0 915 181 C, HW: 1K0 915 181 A.
Component: J367-BDM H07 0125
Serial number: 00000000002790982766
Address 69: Trailer (J345) Label file: DRV\1K0-907-383-V2.clb
Part number SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Trailer H07 0070
Revision: 3A001001 Serial Number: 00000126823338
Encoding: 410D000100000000
VCID: 306B62626397C7C153-8064
Address 77: Telephone Label file: DRV\3C0-035-730.lbl
Part number SW: 5N0 035 730 C. Hardware: 5N0 035 730 C.
Component: J412 8506
Revision: 00019000 Serial Number: 0000B7A154419
Encoding: 0026145
VCID: 285B8A029B478F018B-807C
End----------------------------(Duration: 03:0icon_cool.gif-----------------------------
VW ID 7 GTX
Translated on 17-10-2026, 20:27.
Post30-08-2017, 21:30    Subject: Oversteering Issues: 3C5 CBAB Model Analysis Quote
Hi Simon,
I would log the actual values of air mass, boost pressure, flow/torque limits, and fuel pressure, and then set a marker when the error occurs.
Then you can see what's going wrong. If the error occurs very rarely, all you can do is wait until it happens more often... icon_confused.gif
Translated on 17-10-2026, 20:28.
findus170
Post31-08-2017, 20:44    Subject: Oversteering Issues: 3C5 CBAB Model Analysis Quote
Okay, thank you, Rainer.
Continue driving, observe, and log any sightings if there's a concentration of them.
Greetings.
VW ID 7 GTX
Post31-08-2017, 21:12    Subject: Oversteering Issues: 3C5 CBAB Model Analysis Quote
One more thing that came to mind: Check the fuse box for any signs of corrosion icon_idea.gif and inspect the fuses.
Translated on 17-10-2026, 20:29.
Sebikom1
Post04-09-2017, 16:48    Subject: Oversteering Issues: 3C5 CBAB Model Analysis Quote
"I'm increasingly hearing from people in my circle about issues like engine misfires and AGR (selective catalytic reduction) problems after the NOx update."
Sometimes, my T6 device "freezes" or "gets stuck" after the update.
Sebastian.
A4 B7 2.0 TDI BLB
A4 B6 1.9 TDI BKE
findus170
Post04-09-2017, 22:41    Subject: Oversteering Issues: 3C5 CBAB Model Analysis Quote
I will still check the fuses.
Otherwise, the car behaves the same as before in terms of NOx emissions; there's no noticeable difference.
Greetings.
VW ID 7 GTX
Translated on 17-10-2026, 20:30.
No new posts Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Kurzer Aussetzer beim AHF Diesel Engine Technology
No new posts Brief interruption at AJM Diesel Engine Technology
No new posts Turbo Problems Audi A2 1.4 TDI - Intermittent Issues Diesel Engine Technology
No new posts Fuel Injector Cleaning: Improve Performance Diesel Engine Technology
