Exhaust Pressure Sensor Error: High Input Signal:(
mckay1717
2008 Seat Ibiza
Post01-09-2017, 21:50    Subject: Exhaust Pressure Sensor Error: High Input Signal:( Quote
Hi, I installed a new, inexpensive sensor from an aftermarket supplier, and I didn't register it. So far, everything seemed fine, and the light has remained off since then.
Normally, I only drive around the city, and about once a week I drive 50 km on the highway and then another 50 km back.
Okay, so I drove 450 km one way and then another 450 km back, a total of 900 km, on the highway, with an average speed of 100 km/h, and longer stretches at 160-180 km/h. On the way back, the particulate filter warning light came on for the first time; I had never seen it before.
After a stop at a rest area, the particle light was off again, but now the engine light is on again, and it's telling me that the exhaust pressure sensor input signal is too high icon_sad.gif.
I would now like to obtain an original sensor.
The question is, does the control unit need an update, or is it sufficient to simply calibrate the sensor?
"For sale on eBay: ..."
For engine codes BJL, BLS, BRS, BMM, BKD, BNA, BRT, AXD, and AZV, an update of the engine control unit is required by the vehicle manufacturer.
Adapting the differential pressure sensor to the control unit is always necessary, regardless of the engine code, and requires the use of a vehicle diagnostic tester
I have a BLS (presumably referring to a specific device or system), so according to the seller, it seems like an update is also needed in addition to the initial setup.
Translated on 04-09-2026, 14:48.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
dieselschrauber likes this.
Post01-09-2017, 21:53    Subject: Exhaust Pressure Sensor Error: High Input Signal:( Quote
Good evening.
Please observe the forum rules icon_smile_thumb_up.gif.
Then, an automated scan would be very helpful for assistance.
Translated on 04-09-2026, 14:50.
Post16-09-2017, 11:55    Subject: Exhaust Pressure Sensor Error: High Input Signal:( Quote
Posts like this should actually be posted in the "Diesel Engine Technology" forum, which is reserved for our customers. icon_idea.gif Please see the terms of service.
You can participate in the Dieselschrauber diagnostic contest, and you might win a VCDS HEX-V2 from us. icon_wink.gif
Translated on 04-09-2026, 14:51.
No new posts DPF Code P2463: High Soot Mass Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0402 Error: EGR Flow Too High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Code 539 AFN: Max Speed 180, High Fuel Consumption! Diesel Engine Technology
No new posts Fehlercode 65535,Leerlauf ztw. nach dem Starten zu hoch On-Board Diagnostics (OBD)
No new posts High Boost Pressure: Causes & Solutions Upload
No new posts Boost pressure too high On-Board Diagnostics (OBD)
