Injector Problems: Common Issues & Solutions
wolf74
Post18-10-2017, 17:55    Subject: Injector Problems: Common Issues & Solutions Quote
I drive a Hyundai Terracan 2.9 (manufactured in 2001, with 250,000 km on the odometer) and I'm having problems with the injectors. The engine is running very rough.
During an injector test, it was found that all 4 injectors were far outside the tolerance range. icon_sad.gif
"The repair would cost me approximately 600 euros, which is almost more than the car's value, especially in its current condition. I also don't really want to invest that much money in the car. Furthermore, this would be the third injector replacement within 5 years and 100,000 kilometers."
"I saw that the injector modules from Delphi cost around 50 euros. Can I replace the nozzle myself? And what's the worst that could happen if I reinstall the injectors without testing them and using new software?"
2) Is it possible for the coating on high-pressure lines to detach and cause damage to the nozzle needles?
Best regards.
Wolfgang.
Translated on 03-08-2026, 8:50.
Karma: +1344 / -0   Thank you, like it!
Post18-10-2017, 20:42    Subject: Injector Problems: Common Issues & Solutions Quote
The problem may not necessarily be caused by the injector needles and/or injector bodies.
The valves in the injectors are the real key component.
And with that, you're no longer dealing with the nozzle modules themselves, but rather with replacing the injectors.
Translated on 03-08-2026, 8:52.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Injectors: 2.7L & 3.0L V6 Engines Diesel Engine Technology
No new posts CR-SG: Why Only 6 Injectors? Diesel Engine Technology
No new posts Injector Calibration: How to Calibrate Injectors Diesel Engine Technology
No new posts Injector Overhaul: Repair or Replace? Diesel Engine Technology
