Immobilizer: Disable After ECU Replacement
PeterP.
Post27-10-2017, 15:25    Subject: Immobilizer: Disable After ECU Replacement Quote
Hi, here's the text:
Caddy2 1.9 Tdi ALH. I had to replace my engine control unit because the old one had water damage. The previous owner had already deactivated the immobilizer on the old unit.
Now I'm standing here with a new control unit.
I only have the control unit and a licensed VCDS software.
Is there a chance?
Translated on 28-08-2026, 9:20.
Post27-10-2017, 16:50    Subject: Immobilizer: Disable After ECU Replacement Quote
No!
Translated on 28-08-2026, 9:21.
chli1976
Post28-10-2017, 9:32    Subject: Immobilizer: Disable After ECU Replacement Quote
Do you have a way to read and write to the EEPROM or flash memory? If so, I might be able to help.
VCDS
Wiesel
Post30-10-2017, 11:34    Subject: Immobilizer: Disable After ECU Replacement Quote
Das dürfte noch eine MSA15 sein. No Flash icon_wink.gif.
The tools that worked with the EDC15 system weren't helpful in this case.
@ Peter
A car scan, or at least a scan of the MSTG (Main System Test Group), would certainly be helpful.
Translated on 28-08-2026, 9:22.
chli1976
Post30-10-2017, 13:36    Subject: Immobilizer: Disable After ECU Replacement Quote
Then he needs to read the EEPROM using a programmer.
VCDS
vwSchrauber
Post31-10-2017, 11:32    Subject: Immobilizer: Disable After ECU Replacement Quote
If the engine control units (ECUs) are 100% identical, you can simply solder the EEPROM with the disabled WFS (presumably a specific feature) onto the "new" ECU. This has the advantage that the mileage displayed by the instrument cluster will match the mileage recorded by the engine control unit.
The EEPROM is likely a B58253 DIL8 component, but in a surface-mount (SMD) package.
Wiesel
Post31-10-2017, 18:29    Subject: Immobilizer: Disable After ECU Replacement Quote
However, a prerequisite is that...
that the EEPROM survived the "failure" of the ECU without any damage.
Translated on 28-08-2026, 9:23.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Disable immobilizer for 1Z engine? On-Board Diagnostics (OBD)
No new posts How to disable immobilizer without VIN. How? On-Board Diagnostics (OBD)
No new posts Steuergerättausch 2.5 TDI On-Board Diagnostics (OBD)
No new posts Disable T4 WFS: How to & Troubleshooting On-Board Diagnostics (OBD)
