Caddy Engine Control Unit - Radiator Fan
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
manny11
Post19-11-2017, 12:53    Subject: Caddy Engine Control Unit - Radiator Fan Quote
Hello everyone.
Error = Radiator fan control.
When the car is unlocked and a door is opened, the radiator fan immediately starts.
Does anyone have any ideas? The cables seem to be okay so far.
Manny
Translated on 26-09-2026, 4:58.
olli
Karma: +46 / -0   Thank you, like it!
dieselschrauber likes this.
Post19-11-2017, 13:54    Subject: Caddy Engine Control Unit - Radiator Fan Quote
I have no idea if this is the same for the Caddy... In the A6 4F, the radiator fan control units often fail due to corrosion inside or on the control unit itself. The effect is the same; the fan runs continuously. You could try running an actuator diagnostic test; in the A6, it's possible to control the fans individually.
Best regards from Berlin.
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 26-09-2026, 4:59.
manny11
Post19-11-2017, 18:03    Subject: Caddy Engine Control Unit - Radiator Fan Quote
Okay, that's different for the Caddy; it's controlled directly via the engine control unit.
Unfortunately, none of the companies that specialize in repairing electronic control units are able to fix this.
Translated on 26-09-2026, 5:00.
Post19-11-2017, 18:26    Subject: Caddy Engine Control Unit - Radiator Fan Quote
Autoscan?
There should be a monitoring section where you can see when the radiator fan is activated.
Translated on 26-09-2026, 5:01.
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vibrating Cooler Fan: Troubleshooting & Fixes Diesel Engine Technology
No new posts V157 Fan & Cooler Repair: Get it Fixed! On-Board Diagnostics (OBD)
No new posts Cooler Fan Always On: Troubleshooting & Fixes Diesel Engine Technology
No new posts Check cooler fan function? Diesel Engine Technology
