1.9 TDI Starting Problems: Troubleshooting Guide
mauze
Post25-11-2017, 20:57    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
I'm new here. My name is Maurice, and I'm 18 years old. I've been reading for a while, and now I have a question. I installed a 1.9 TDI AFN engine in my Golf 2, but I've never heard that engine running before.
Now, let's get to the problem:
"When starting, it sounds like it tries to start once, then cuts out briefly, and then starts up again immediately. I've attached an audio file that describes it much better. When it's running, it works really well and has good power, but I don't know if it could be better. I'm just annoyed by this strange starting process. Do you have any ideas what it could be?"
Maurice.
1.9 TDI Starting Problems: Troubleshooting Guide - TDI.mp3
 File size:  1.33 MB
 Viewed:  136 times
Translated on 12-09-2026, 12:47.
Post25-11-2017, 21:27    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
My suspicion is that the fuel injection amount (initial amount) is too high due to a faulty coolant temperature sensor. This then causes the engine speed to increase, and the engine control unit subsequently reduces the throttle.
The coolant temperature can be displayed in the measurement blocks of the engine control unit using VCDS.
You can also see them in the OBD2 diagnostic data, for example, using software like KOBD2Check.
A new coolant temperature sensor for the engine costs less than 10 EUR. Also, check the cables and connectors.
Translated on 12-09-2026, 12:49.
mauze
Post25-11-2017, 21:51    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
Hi Rainer,
Thank you very much for the super-fast response. I will get the sensor right away. I just unplugged the sensor connector, and the starting behavior is a little better, even at a higher RPM, although the up-and-down fluctuation during starting is not completely gone. Is that normal with the connector unplugged?
Just for fun, I unplugged the connector from the throttle potentiometer, and it started perfectly the first two times, but then the error code reappeared.
Best regards, Maurice.
Translated on 12-09-2026, 12:50.
Post25-11-2017, 22:14    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
With the coolant temperature sensor disconnected, the behavior should be strange; the engine control unit will then use the maximum amount of fuel for starting.
It's possible that the fuel injection pump is slightly miscalibrated, or that a tuning box has been installed. The same applies to a potentially faulty throttle position sensor. Without a proper diagnosis, you won't be able to determine the cause.
Since the coolant temperature sensor is very inexpensive and often fails, I would start by testing that.
Translated on 12-09-2026, 12:51.
mauze
Post26-11-2017, 16:07    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
Okay, I'll get the temperature sensor tomorrow and install it. Hopefully, that will fix the problem.
Could it possibly be the flywheel? The engine comes from a car that had a minor front-end collision. I also have a strong rumbling/humming sound when the engine is idling, but I haven't noticed any rumbling while driving. It's not very audible in the audio file, but when you turn the key, the engine immediately shuts off. That doesn't sound quite right...
Maurice.
Translated on 12-09-2026, 12:53.
Post26-11-2017, 16:11    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
Why do you think the flywheel could significantly affect the engine speed during startup?
mauze
Post26-11-2017, 17:12    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
I could now imagine that the flywheel, due to the accident, has a significant imbalance, and that this imbalance could become noticeable during the starting process, in the way that I am experiencing it.
Post26-11-2017, 17:27    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
mauze wrote:
I could now imagine that the flywheel, due to the accident, has a significant imbalance, and that this could become noticeable during the starting process, in the way that I have experienced.
And after starting, you no longer notice the imbalance icon_question.gif, that's quite a thought process...
Translated on 12-09-2026, 12:54.
mauze
Post26-11-2017, 17:32    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
I already wrote that it makes a very loud rumbling noise when idling. It also makes a noise at higher RPMs, but not as loud.
Translated on 12-09-2026, 12:55.
Post26-11-2017, 17:44    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
mauze wrote:
I had written that it makes a very loud humming noise when idling.
At higher RPMs, it also makes the noise, but not as strongly...}
The engine sounds normal when running on the MP3.
Post29-11-2017, 13:40    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
Technical articles on TDI starting problems:
mauze
Post29-11-2017, 20:07    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
Okay, I finally got around to installing the water temperature sensor today, but it didn't lead to any improvement. Then, I quickly turned the key, and the engine started up as it should.
I then took a second ignition switch from the stock and now the problem is gone.
But thank you very much for your help!!!
Translated on 12-09-2026, 12:56.
Post29-11-2017, 20:35    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
Ah... and how do you explain the effect? Did you wake up in the morning and think: "Ah, today I'm going to install a new ignition switch" icon_question.gif?
Translated on 12-09-2026, 12:57.
mauze
dieselschrauber likes this.
Post29-11-2017, 21:36    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
Okay, so I'm revising my previous answer. I replaced the temperature sensor, but the problem was still there. I even ran the engine and moved it around the yard, so there definitely should have been water flowing to the sensor. Then, out of frustration, I just turned the key all the way and it started. I simply unplugged the connector from the old sensor and plugged it into the new one, and it immediately started working. Then I reconnected the old ignition switch, and the problem reappeared.
I think the ignition switch in the old ignition system is faulty. When you turn it to position 1 (ignition on), then to position 2 (start), the switch briefly interrupts the ignition as you return from the start position, and then when you're back in position 1, the ignition is on again.
Translated on 12-09-2026, 12:58.
mauze likes this.
Post29-11-2017, 21:48    Subject: 1.9 TDI Starting Problems: Troubleshooting Guide Quote
Thank you for your feedback!
Translated on 12-09-2026, 12:59.
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Fuel Filter: Starting Problems? (ATU) Diesel Engine Technology
No new posts White Smoke & Startup Problems Diesel Engine Technology
No new posts BMW Diesel: Starting Problems with CMR 1u2 Diesel Engine Technology
No new posts VW/Audi V6 TDI Kennbuchstabe AKE mit Startschwierigkeiten Diesel Engine Technology
