Nozzles with different part numbers were used (instead of 0414720210, the part number 0986441561 was used; and instead of 07Z130073F, the part number 07Z130073FX was used). According to Bosch, these nozzles are the correct ones, as the part number was likely changed at some point.
It still seems very strange to me that all 5 elements are defective
The background information can be read here:
https://community.dieselschrauber.org/en/viewtopic.php?t=29744
After that, all 5 components were disassembled and sent to Bosch. They then inspected 3 of the nozzles for a considerable fee. After discussing it with me, we decided not to inspect the remaining 2, as it was highly likely that they had the same defect. There was also a testing fee of 80 euros per component.
I'm just wondering how the engine was running perfectly before all this happened, aside from the issue with the PDE seals. A mechanical defect would be understandable, but an electrical failure affecting everything at once?
...but well, the nozzles went through various hands, and I hadn't written down the numbers of the nozzles before giving them to other people
