ESP Quiz: Test Your English Skills!
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
JRoth
Post24-05-2005, 23:33    Subject: ESP Quiz: Test Your English Skills! Quote
Hello, dear VP 37 specialists!
I'm having a small mapping issue with an ESP.
"Jnd." sold me this ESP (Electronic Stability Program) module as an "AFN pump" from a Golf 3.
Can you tell from the picture if this pump is from an AFN engine?
I would be extremely grateful! If any further information is needed, I will provide it.
Sure, I'd be happy to!
The part number on the pump housing is HDK216. Unfortunately, the actual part number is no longer legible! icon_mad.gif
JRoth
 Stammt diese ESP aus einem AFN ?
 File size:  296.93 KB
 Viewed:  2649 times
Passat Variant 35i 1Z 05/02 - 01/05
Ford Galaxy AFN 01/05 -07/06
Ford Galaxy 08/06 - 08/09
Translated on 03-08-2026, 7:18.
rinderwahnsinn
Post25-05-2005, 6:56    Subject: ESP Quiz: Test Your English Skills! Quote
So, that picture is a lost cause.
From a certain angle, all VP37s look the same.
What does it mean that the part number is completely illegible? It appears to be stamped or laser-etched. With a fine abrasive cloth and some care, it's definitely possible to make it readable again. Unless someone intentionally tried to obscure it.
Translated on 03-08-2026, 7:19.
Post25-05-2005, 8:10    Subject: ESP Quiz: Test Your English Skills! Quote
Okay, hier ist die Übersetzung:
"Please provide the text you would like me to translate from German to English."
Translated on 03-08-2026, 7:20.
JRoth
Post25-05-2005, 11:12    Subject: ESP Quiz: Test Your English Skills! Quote
The electronic part number appears to have been intentionally removed, possibly by being cut off, for some reason. icon_twisted.gif
In the pump shown in the picture, it appears that the timing of fuel delivery is not adjusted by rotating the pump itself (unlike my AFN pump, which has elongated holes in the pump mounting bracket!), but rather by adjusting the position of the rotor on the shaft.
If everything else fits, I would at least need another impeller... icon_mad.gif
As I mentioned before, I'm happy to provide additional information if needed. The issue is simply this: Someone sold me this pump claiming it was a Golf 3 AFN fuel pump, and I believe...
that simply isn't true!
Thank you in advance for your help!
J. Roth.
Translated on 03-08-2026, 7:21.
FreeTrailThief
Post12-01-2018, 22:42    Subject: Solved: Common Problem & Solution Quote
Hello JRoth,
I once had a problem where my ESP (Electronic Stability Program) failed.
"I then built one myself using a component from an EGR valve from a fourth-generation Golf and an ESP unit. It's been running for about 50,000 km now, but the one from an AFN engine in a third-generation Golf was identical in terms of the connector."
Mfg FreeTrailThief
Translated on 03-08-2026, 7:23.
No new posts Announcements: Quiz: Test your knowledge now! Quiz
No new posts Announcements: Quiz on Diesel Technology / Vehicle Technology, Prize + P... Quiz
