VW CFH 1.6 and 2.0 TDI Oil Pump Timing Belt Replacement Interval
sebv6
2000 Volkswagen Passat Consumption
Post19-12-2017, 20:03    Subject: VW CFH 1.6 and 2.0 TDI Oil Pump Timing Belt Replacement Interval Quote
Hello, some of the VW diesel engines, such as the CFH, have a timing belt that runs in oil and drives the oil pump. There is no information available about a replacement interval. Should the one that I recommend replacing every time I change the timing belt, which I usually recommend doing every 6 years anyway, also be replaced?
Passat TDI PD AWX 12/2000
chli1976
Post20-12-2017, 6:42    Subject: VW CFH 1.6 and 2.0 TDI Oil Pump Timing Belt Replacement Interval Quote
As far as I know, there is no specified interval, but this is not guaranteed.
VCDS
Bergamount
Post17-01-2018, 8:29    Subject: VW CFH 1.6 and 2.0 TDI Oil Pump Timing Belt Replacement Interval Quote
I agree with the previous speaker. However, I would recommend contacting the vehicle manufacturer.
sebv6
Post17-01-2018, 10:58    Subject: VW CFH 1.6 and 2.0 TDI Oil Pump Timing Belt Replacement Interval Quote
OK, that looks suspiciously like a potential weakness...
What do you think? Replace after 6 years?
No new posts Audi Timing Belt Interval: When to Replace? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Timing Belt Replacement Interval Diesel Engine Technology
No new posts Timing Belt Interval AFB/AKN Engine Diesel Engine Technology
No new posts ZR Change Interval: Questions and Answers Diesel Engine Technology
This topic is locked, you cannot edit or reply. Timing Belt AJM: Replacement Interval & Solution Diesel Engine Technology
