Polo 9N3 Window Regulator BUS Issue?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
Post26-07-2017, 15:53    Subject: Polo 9N3 Window Regulator BUS Issue? Quote
Hello everyone,
"On my 2006 Polo 9N3 TDI, the power windows (all of them) only work when at least the parking lights are on. The problem appeared suddenly. Can anyone explain this? There are no error codes stored in VCDS. A scan of all control units yielded no results."
Weird...
Beste Grüße,
Hufe
Translated on 17-09-2026, 10:19.
Hufe likes this.
Post26-07-2017, 21:08    Subject: Polo 9N3 Window Regulator BUS Issue? Quote
I had a similar issue in a Lupo; sometimes, the dashboard warning lights would turn on, even though the car was locked and NO key was inside icon_eek.gif.
Also, here, there are no errors to be seen in the VCDS icon_eek.gif.
The cause was the window lifter motor on the passenger side, and the control unit electronics got wet. icon_idea.gif
Translated on 17-09-2026, 10:20.
Hufe
2004 Audi A6 Avant
dieselschrauber likes this.
Post24-01-2018, 8:24    Subject: Solution: Find the best solutions now! Quote
Door control unit malfunction. Temporarily bypassing the power supply improved the situation.
Replacing the door control unit is essentially unavoidable, as otherwise it will be permanently powered. However, it may be possible to make it switchable via, for example, a light switch.
The end.
Beste Grüße,
Hufe
Translated on 17-09-2026, 10:21.
Post24-01-2018, 8:53    Subject: Polo 9N3 Window Regulator BUS Issue? Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Translated on 17-09-2026, 10:22.
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Window lifter not functioning Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Luop 6X1 MJ 2002, Window regulators stiff Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N window lifter On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Electric Window Regulator for Polo 6N2 (Solved) Transmission, Chassis, Body & Interior
No new posts Audi A3: Electric Window Problem & Repair Transmission, Chassis, Body & Interior
No new posts Polo 1.4 TDI: Limp Mode - Turbocharger Issue Diesel Engine Technology
