1.9 TDI: Car Won't Start - Troubleshooting Guide
UHT
Post17-02-2018, 19:59    Subject: 1.9 TDI: Car Won't Start - Troubleshooting Guide Quote
Hello forum,
I'm having a problem with my VW Golf (model 3).
"It stalls in the evening and won't start in the morning. The engine cranks, but doesn't fire. When I disconnect an injector line, no diesel comes out, and even the return line is empty."
I replaced the diesel filter and the "Knackfrosch" (likely a specific component). I reinstalled the "Absteller" (a type of valve or switch) without using any special tools, and it probably isn't related to the problem. Is it normal that you can disassemble it so easily?
Any other ideas? What is the purpose of the WFS box at the pump?
Translated on 01-08-2026, 13:10.
Karma: +643 / -0   Thank you, like it!
Post18-02-2018, 13:47    Subject: 1.9 TDI: Car Won't Start - Troubleshooting Guide Quote
Is the error memory empty?
Is the fuel injection pump externally sealed?
Have you ever proactively installed check valves in the supply and return lines?
How do you get it to run currently?
Translated on 01-08-2026, 13:12.
UHT
Post18-02-2018, 14:30    Subject: 1.9 TDI: Car Won't Start - Troubleshooting Guide Quote
Yes, the error memory is clear. I don't have anything immediately available regarding the check valve. But shouldn't injecting some ESP fluid directly into the system provide a temporary result?
Currently, it's not working.
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 1.9TDI 4Motion AJM has a hard start Diesel Engine Technology
No new posts HILFE!!! Mein 1.9TDI Bj.97 springt nur noch kalt an!!! Diesel Engine Technology
No new posts kontrollleuchten gehen nicht, únd wagen springt nicht an Diesel Engine Technology
No new posts VW TDI V10 won't start Diesel Engine Technology
