Audi B6 1.8T rattles
vag-driver
Post19-02-2018, 9:49    Subject: Audi B6 1.8T rattles Quote
The Audi belonging to my colleague, as can be seen in the attached video, is making a rattling noise. Upon initial inspection, the chain of the oil pump appears to have stretched, which is likely the reason why the warning light for low oil pressure is constantly illuminated.
The Audi was first registered in July 2003 and has a mileage of 137,000 km.
Now, let's get to the interesting questions:
- Since he continued driving, the primary question is whether the seals and rings could have survived without oil lubrication.
- How expensive and time-consuming is it to replace the chain?
Audi B6 1.8T rattles - VID-20180218-WA0006.mp4
 File size:  10.19 MB
 Viewed:  1259 times
Andreas
Post19-02-2018, 10:32    Subject: Audi B6 1.8T rattles Quote
Since he continued driving, the primary question is whether the seals and rings survived without oil lubrication?
A potential issue could be the turbocharger's bearing lubrication, especially if it has been operated for a period without oil pressure. However, it can be easily checked by removing the intake snorkel.
As for the rest, things might have been okay as long as some oil was still trickling out of the pump and the engine load wasn't too high. It really depends on how long it was driven like that.
My BRE (presumably a vehicle or engine) didn't suffer any oil-related damage, and the engine ran without the oil pump for a short period, with breaks, and under minimal load, totaling perhaps ~2 minutes.
vag-driver
Post19-02-2018, 10:42    Subject: Audi B6 1.8T rattles Quote
He drove another 20-30 km towards home with insufficient oil.
Andreas
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post19-02-2018, 17:20    Subject: Audi B6 1.8T rattles Quote
I once had a customer with a BFB engine. The oil filter was almost completely clogged, and the oil pressure warning light came on. They still drove about 120 km (approximately 75 miles) to get home. I was only allowed to perform the oil and filter change. The engine still runs smoothly approximately 25,000 km later icon_smile_thumb_up.gif.
Of course, it varies from case to case.
Karma: +645 / -0   Thank you, like it!
dieselschrauber and Mpire likes this.
Post19-02-2018, 18:12    Subject: Audi B6 1.8T rattles Quote
I would start by removing the oil pan and checking the condition of the oil pump's strainer to see how much oil sludge is present.
The few kilometers driven, possibly with long-life oil, suggest that this issue is related.
vag-driver
Post19-02-2018, 20:36    Subject: Audi B6 1.8T rattles Quote
The oil pan was already removed last year. No sludge. No clogged filter.
Andreas
vag-driver
Post02-03-2018, 15:01    Subject: Audi B6 1.8T rattles Quote
Statement from a mechanic: Either the oil pump and/or the crankshaft bearings are defective.
Due to the age and condition of the vehicle, it's not economically viable, as my colleague can't do the repairs himself.
Andreas
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Blinking Relay Noise: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Fuel injection pump rattles Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
