Audi A1 1.6 TDI: Jerking During Acceleration
dokky
2013 Volkswagen Golf
Post08-04-2018, 9:03    Subject: Audi A1 1.6 TDI: Jerking During Acceleration Quote
Hello everyone,
We are selling the vehicle mentioned above, first registered in October 2014, with a current mileage of 67,000 km.
"With our car, there's a slight jerk before the power kicks in when the engine speed is below 2000 RPM and with light acceleration. Audi updated the software in the engine control unit (ECU) about 18 months ago, which improved the situation somewhat."
Now we had to do the EA189 update, and since then, the hesitation has become much more noticeable. It only happens when the engine is at operating temperature and below 2000 RPM, especially when you gently press the accelerator. It's normal when you're giving it full throttle.
Audi says that this is something we have to live with, and that adapting the system in small increments hasn't made a difference. A comparable vehicle in the dealer's inventory exhibits the same behavior.
I could borrow a VCDS device from a friendly mechanic to post some readings.
Translated on 01-09-2026, 5:21.
Albrecht
dieselschrauber likes this.
Post09-04-2018, 22:01    Subject: Audi A1 1.6 TDI: Jerking During Acceleration Quote
"Our newly acquired Skoda Roomster (year 2011, 119,000 km, also with the 1.6 TDI CAYC engine) also exhibits this jerking behavior during load changes, particularly in the low RPM/load range."
I also noticed that it's quite unpleasant.
The gradient, which depends on the accelerator pedal position, is likely very small at the initial percentage of accelerator pedal travel.
steeply applied (e.g., for overvoltage protection).
The powertrain also seems to have quite a bit of play, which intensifies the feeling of jerking.
Greetings, Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 01-09-2026, 5:23.
dokky
Post20-04-2018, 7:21    Subject: Audi A1 1.6 TDI: Jerking During Acceleration Quote
"Then we'll probably just have to live with it. Audi offered to replace the injectors, but since all the values are within range and the engine is running smoothly, we're not going to have them replaced for now."
It's just annoying when you have to keep up with the traffic without cruise control.
Translated on 01-09-2026, 5:24.
No new posts 1.9 PD-TDI ATD engine: hard shifting/jerking under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0044 AMF, Creaking noise during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, noises during load changes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Engine Jerk with DPF: Causes & Solutions Diesel Engine Technology
No new posts Jerks during load change Diesel Engine Technology
No new posts BLS - AGR errors and jerking during acceleration when in ... Diesel Engine Technology
No new posts Car Shakes at 160 km/h: Sudden Jerk, No Power? Diesel Engine Technology
