Druck im Kühlsystem baut sich auch bei kaltem Motor nicht ab | Posts 16+
Go to page: Previous  1, 2
Bernd68
Post12-03-2018, 16:27    Subject: Quote
Hi there,
Thank you for your thoughts.
I'm just going to drive it and not think about it anymore. It's been like this for a while now, and the car has already far exceeded its expected lifespan. If there are any issues with the timing chain etc., I won't be repairing anything here.
I still have it in the back of my mind to replace the entire engine – who knows…
I still have an AFN engine lying around in the garage - complete with transmission.
How much effort is involved in installing an AFN instead of an AHU?
I also have a control unit.
The wiring harness should be the same.
Exhaust? The connection for the downpipe is different – I also have one from an AFN engine. I actually intended to install it in a T3 van.
Bernd
Translated on 25-08-2026, 7:47.
Post13-03-2018, 16:42    Subject: Quote
The pressure will build up again as soon as heat is transferred to the coolant; it's unavoidable. The keyword here is vapor pressure. In a closed system, the same temperature-dependent pressure will always be established above and within the liquid.
Okay, with a properly functioning head gasket, it will be minimal because... the coolant has reached its operating temperature and will not expand much further, as the temperature difference (delta t) is much smaller... the engine is already warm... and therefore, the pressure difference (delta p) is also lower. When you open it, there's a brief hiss and then it stops. With a defective head gasket, it will hiss for a much longer time. Of course, the temperature must remain constant between tests.
It will look similar with the piano burnishing process, but with less pressure and at a lower temperature.
One would have to conclude that more pressure is being generated than one might expect based on the temperature. And it seems our colleague has already made this observation.
I meant that in the case of "piano," there might not be any gas transfer occurring, and consequently, the cold system could be pressureless.
Translated on 25-08-2026, 7:49.
Karma: +1344 / -0   Thank you, like it!
Post13-03-2018, 20:35    Subject: Quote
@ Car service - see private message.
Translated on 25-08-2026, 7:51.
Post14-03-2018, 0:54    Subject: Quote
As I said, practice makes perfect, and it's not much effort.
Perhaps this will be helpful to future generations...
In this sense icon_wink.gif.
Translated on 25-08-2026, 7:52.
Bernd68
Post14-03-2018, 1:14    Subject: Quote
I will try that this weekend. Let's see icon_smile_thumb_up.gif.
Bernd
Bernd68
Post07-06-2018, 22:00    Subject: Quote
Hi there,
So, he's still running icon_smile_thumb_up.gif.
Regarding the pressure test: As soon as I start the engine and it warms up, this overpressure builds up in the system. Just driving for 5 kilometers is enough – then I stop, let it cool down, and the overpressure remains.
Nothing builds up over a distance of 500 meters.
I find it remarkable that the engine, despite this damage, can still handle long stretches of highway at high speeds without any problems.
Over the weekend, I drove 1000 kilometers non-stop – from Denmark to Southern Germany – in very hot weather.
Bernd
Translated on 25-08-2026, 7:53.
No new posts A4 Doku: Engine Control Not Connecting to WFS. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts VP37 Pump: Low Pressure? Troubleshooting Guide. Diesel Engine Technology
No new posts Boost pressure builds up too slowly (Cupra TDI), VAG Com log Diesel Engine Technology
No new posts The steering angle at the BRS motor does not change Diesel Engine Technology
No new posts Intake valve not closing long enough, causing engine shake! Diesel Engine Technology
