P244B - Diesel Particulate Filter - Differential Pressure too High (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post09-06-2018, 12:24    Subject: P244B - Diesel Particulate Filter - Differential Pressure too High Quote
Error code P244B - Diesel particulate filter differential pressure too high, Bank 1 has the following possible causes:
- Faulty Diesel Particulate Filter (Aftermarket filter of inferior quality or simply not suitable for the vehicle).
- Particulate filter differential pressure sensor is defective or not compatible with the vehicle.
Possible Symptoms:
- Turn on the engine light
- DPF warning symbol
- Performance loss
- Excessive fuel consumption
More information about the diesel particulate filter and its cleaning:
/viewtopic.php?t=24243
Typical differential pressures across the diesel particulate filter:
/viewtopic.php?t=24222
Ratings - P244B - Diesel Particulate Filter - Differential Pressure too High
No new posts P244B Diesel Particulate Filter Differential Pressure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF & Environmental Zones: Quick FAQ Technical Articles
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts DPF differential pressure slightly high Diesel Engine Technology
No new posts AGR Function Test: High Differential Pressure? Diesel Engine Technology
No new posts Important: DPF Back Pressure Normal Values Diesel Engine Technology
No new posts Differential pressure DPF vs. exhaust backpressure (and S... Diesel Engine Technology
