1,4 TDI: AGR-Ventil & Lambdasonde defekt? | Posts 32+
Go to page: Previous  1, 2, 3
Post29-04-2018, 14:13    Subject: Quote
So, I see something that can be unscrewed, where you can preferably take measurements. icon_rolleyes.gif
Did you actually drag that thing around with all those cables and hoses attached, scraping it along the ground?
If that's the case, it's better to have a workshop do the job instead of continuing to cause further damage. icon_idea.gif
Translated on 13-08-2026, 0:37.
stolley
Karma: +38 / -1   Thank you, like it!
Post29-04-2018, 14:50    Subject: Quote
dieselschrauber wrote:
So, I see something that can be unscrewed, where you can measure properly. icon_rolleyes.gif
Of course not, Rainer!
Okay, then I'll check the engine side. It's not possible to access it from the other side.
I thought it was important and only made sense to measure from both sides.
Thank you!
Translated on 13-08-2026, 0:38.
stolley
Post29-04-2018, 16:03    Subject: Quote
My measurements indicate that the chambers are between 50% and 90% empty (possibly even 100%, as I can only estimate the exact length of the chambers).
It's not that bad, is it?
Translated on 13-08-2026, 0:40.
Post29-04-2018, 16:52    Subject: Quote
You don't know how long the ceramic material is inside, so a USB endoscope inserted through the exhaust pipe would be helpful, or you could try searching online for images of your specific type of cut-open DPF.
It might be possible to insert a garden hose into the exhaust pipe and observe when it reaches the differential pressure sensor connection, allowing you to estimate how far it can be inserted towards the ceramic component.
It's not about the 5mm; it's about whether 10%, 40%, or 90% of the ceramic is exposed.
In some previous posts, you mentioned acquiring a G450, but you didn't specify the outcome or whether the maximum differential pressure and offset values changed.
Translated on 13-08-2026, 0:41.
stolley
Post30-04-2018, 15:13    Subject: Quote
I've reassembled everything in the meantime, including the new G450.
I set the ash mass to 10g and trained the G450 using the five-cycle ignition-on-ignition-off procedure.
So far, there have been no further error messages, but I've only driven about 120 km. I haven't yet taken any measurements of differential pressure and offset. Does this measurement necessarily have to be performed under full load?
Translated on 13-08-2026, 0:42.
stolley
Post01-05-2018, 21:52    Subject: Quote
Today, I wanted to check the differential pressure. Strangely enough, it was "0," whether the system was turned off or during operation.
Since I also had a short circuit in the error memory, I checked the wiring of the G450. And sure enough, there was a broken wire!
I found a wonderfully functional tool for removing the pins: an LED! The wire of a paperclip was too thick for this connector. I soldered a new cable onto the remaining cable stub and covered it with heat-shrink tubing.
"And so, I once again had readings from the differential pressure sensor."
"I'm adding this here. Can you interpret it for me?"
Thank you very much!
Log-A-VA 1101-WVWZZZ9NZ8B031810-411771km-Log-Differenzdruck.CSV
 File name:  Log-A-VA 1101-WVWZZZ9NZ8B031810-411771km-Log-Differenzdruck.CSV
 File size:  40.11 KB
 Downloaded:  213 times
 File name:  IMG_8804.jpeg
 File size:  992.97 KB
 Downloaded:  191 times
 File name:  IMG_8802.jpeg
 File size:  1.18 MB
 Downloaded:  198 times
 File name:  IMG_8803.jpeg
 File size:  926.43 KB
 Downloaded:  220 times
 File name:  IMG_8788.jpeg
 File size:  1.37 MB
 Downloaded:  214 times
Translated on 13-08-2026, 0:44.
stolley
Post18-05-2018, 8:21    Subject: Quote
A brief update on the results of the DPF cleaning:
After driving almost 2000 kilometers, I've noticed that the regeneration cycle of the DPF has extended to approximately 450 km!
Translated on 13-08-2026, 0:45.
Post18-05-2018, 10:37    Subject: Quote
stolley
Post10-06-2018, 20:13    Subject: Quote
Hello everyone,
I finally managed to pressure test the intercooler system!
Result: everything is sealed tight!
I read elsewhere that a faulty oxygen sensor could be responsible for the "mixture too rich" error.
What do you think about it?
Is there a way to measure the lambda sensor using VCDS in some way?
Translated on 13-08-2026, 0:46.
stolley
dieselschrauber likes this.
Post17-07-2018, 9:03    Subject: Quote
Hello everyone!
I replaced the oxygen sensor in my Polo this weekend.
And indeed, the original error has not occurred again so far (signal too strong)!
So, maybe this is also interesting for everyone else who's getting the same error message!
After 422,000 kilometers, you can certainly replace a probe like that sometimes! icon_biggrin.gif
Translated on 13-08-2026, 0:47.
Post17-07-2018, 11:03    Subject: Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Translated on 13-08-2026, 0:48.
No new posts Lambda Values: Definition & Regulations Technical Articles
No new posts P0170 - Fuel Mixture Control (Oxygen Sensor Circuit Malfu... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lambdasonde defekt? Ladedruck Soll/Ist und Null Plan Diesel Engine Technology
No new posts 2.0 TDI AGR Valve: Faulty & Replacement Guide Diesel Engine Technology
No new posts 3.0 TDI Problems: Lambda Sensor/Oxygen Sensor Diesel Engine Technology
No new posts O2 Sensor for V6 TDI 3.0/2.7: Which one? Diesel Engine Technology
