Adjusting the ACV half-wave differentiator
georgmech
Post13-08-2018, 9:32    Subject: Adjusting the ACV half-wave differentiator Quote
Hello, can anyone tell me how to properly adjust the half-value differential sensor on a VP37 injection pump from an ACV T4 using VCDS? Someone repaired it a while ago, and now I'm occasionally getting the error message "Target quantity upper - lower value outside tolerance" intermittently. I initially thought about the typical metal shavings that can accumulate in signaling systems, but everything was clean.
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Back to top Profile PM Email
Post13-08-2018, 20:22    Subject: Adjusting the ACV half-wave differentiator Quote
Hello, can anyone tell me how to properly adjust the half-wave differential sensor from a VP37 on an ACV T4 using VCDS?
It depends on what was done to the pump. If only the position of the fuel injection control unit has been adjusted, set the injection amount to approximately 4-5 mg/hour at idle with the engine at operating temperature (without any accessories running).
If the standard controller itself has been modified, read the values for the minimum and maximum travel limits from an identical motor and adjust the controller's own ESP (Electronic Stability Program) to match those values.
Karma: +1344 / -0   Thank you, like it!
Post13-08-2018, 21:06    Subject: Adjusting the ACV half-wave differentiator Quote
The power supply can only be adjusted in one direction: either to increase the voltage or to decrease it.
What values does MWB 19 provide when ignited?
georgmech
Post13-08-2018, 22:01    Subject: Adjusting the ACV half-wave differentiator Quote
0.600 4.360
Post13-08-2018, 22:28    Subject: Adjusting the ACV half-wave differentiator Quote
You mean the lower value is 0.6 V, and the upper value is 4.36 V.
For the 1Z, both values would be at their maximum. Nothing could be achieved by adjusting it.
I need to think about this.
georgmech
Post13-08-2018, 23:01    Subject: Adjusting the ACV half-wave differentiator Quote
Yes, exactly. What happens if the value is incorrect? I can go down to 0.5 volts. I also have an ACV reading of 0.650 volts, which I just read.
Post14-08-2018, 6:23    Subject: Adjusting the ACV half-wave differentiator Quote
What does the MSG (Message) from the second ASV (Autonomous Surface Vehicle) in Block 19 say?
georgmech
Post14-08-2018, 8:55    Subject: Adjusting the ACV half-wave differentiator Quote
4.85 volts
dieselschrauber likes this.
Post14-08-2018, 9:10    Subject: Adjusting the ACV half-wave differentiator Quote
Okay, hier ist die Übersetzung:
"It would be nice if you could write complete sentences sometimes, and provide all the necessary information!" Lower value, upper value, etc.
What was the exact error message, including the code? "Upper - lower value outside tolerance" is a bit strange.
No new posts Geschwindigkeitsanzeige justieren On-Board Diagnostics (OBD)
No new posts Speedometer adjustment, NO, not the odometer display :) Diesel Engine Technology
