Audi A3 TDI: Location of Engine Control Unit (ECU)
joe
Post28-10-2003, 7:31    Subject: Audi A3 TDI: Location of Engine Control Unit (ECU) Quote
'In my Audi, the engine shuts off after just 2 kilometers (see my post from yesterday).'
I've now resoldered relay 109, and the error hasn't reappeared yet, but it doesn't necessarily mean anything.
On that occasion, I looked for the engine control unit but couldn't find it.
Where is it?
Could the MSG (Main System Ground) be located under the battery? There's a thick cable bundle running to that area.
It would be a great spot, but if battery acid leaks out, the entire system is immediately compromised.
Or am I wrong?
Translated on 23-07-2026, 11:43.
Andy
Post28-10-2003, 7:45    Subject: Audi A3 TDI: Location of Engine Control Unit (ECU) Quote
The control unit will likely be located, as usual, next to the windshield wiper motor inside the water reservoir. Remove the covers and you'll see...
Best regards, Andy.
Translated on 23-07-2026, 11:45.
Post28-10-2003, 8:55    Subject: Audi A3 TDI: Location of Engine Control Unit (ECU) Quote
Where is that thing?
Located in the water reservoir, centered under the plastic cover. Unfortunately, to access it, the windshield wipers must be removed and the wiper mechanism disassembled. icon_rolleyes.gif
joe
Post28-10-2003, 10:55    Subject: Audi A3 TDI: Location of Engine Control Unit (ECU) Quote
Thank you!
Yes, when I was wiring the cruise control system, I had to remove the windshield wiper motor as well.
I hope I don't have to deal with that thing.
Translated on 23-07-2026, 11:46.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
This topic is locked, you cannot edit or reply. Adjust the engine control unit (ECU) for Audi A3/8P On-Board Diagnostics (OBD)
No new posts Replacing the engine control unit (ECU) for an Audi A4 B5... Gasoline Engine Technology
No new posts Audi engine control unit (ECU) AAT - engine On-Board Diagnostics (OBD)
No new posts Audi 80 B4: Engine Control Unit (ECU) Not Responding On-Board Diagnostics (OBD)
