Turbocharger Repair 1.9 TDI ASZ (Weblog Toxic89)
Dieselschrauber - Index
Viewing profile: Toxic89
Avatar All about Toxic89
[0.01% of all posts / 0.00 posts per day]
Show all posts by Toxic89
Website:
Occupation:  Kfz-Ing.
Interests:  Motorentechnik
Karma:  +3 / -0 Karma History - Thank you, Like / Dislike
Quiz points:  0
Support Package:  Premium Support
Contact Toxic89
Email Address:
Private Message:  PM
Weblog - Toxic89
Post16-10-2018, 19:21    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Hello everyone, and thank you for this great forum and the wonderful community.
Having had the opportunity to research and find many valuable pieces of information here, I would like to share some knowledge and experiences in return, in order to further enrich this forum.
The attached document (original creation) describes the repair of a turbocharger for the 1.9 TDI engine produced by Volkswagen AG, featuring a pump-injector system and bearing the engine code ASZ (96 kW / 130 hp).
I would like to submit this document as a "technical article." Unfortunately, I am not familiar with the procedure for doing so.
I would be very grateful for a tip.
Best regards, toxic89.
Man muß die Dinge so einfach wie möglich machen. Aber nicht einfacher. [Einstein]
Translated on 07-08-2026, 18:56.
Profile PM
Post18-10-2018, 19:23    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Nice. But how did you get rid of that rash?
Translated on 07-08-2026, 18:57.
Profile PM WWW Garage
Post18-10-2018, 20:28    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Hello Rainer.
The supplied housing assembly was delivered as a balanced unit consisting of: the casing, shaft with gears, and bearings. No balancing was required.
Best regards, Kevin.
Translated on 07-08-2026, 18:58.
Profile PM
Post30-10-2018, 21:52    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Thank you very much! It is available online: https://community.dieselschrauber.org/en/viewtopic.php?t=30425 icon_wink.gif
Post31-10-2018, 5:27    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Could you perhaps add an illustration to clarify it?
- An image of the integrated charger (hull assembly with both housings).
- how the hull assembly was disassembled;
Translated on 07-08-2026, 18:59.
Profile PM
Post31-10-2018, 13:34    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Hello Herbert.
Thank you for your suggestion.
Unfortunately, I didn't take many pictures of the repair process, and I can't edit the post anymore either! It seems that editing is only possible within 720 minutes after creating the thread.
Regarding the image material:
You can find images of the complete turbocharger by searching for "GT1749VA" on relevant search engines.
- how the hull assembly was disassembled.
From the old main body, I only removed the shaft to inspect the seal. The only noteworthy thing is that the drive shaft (on the compressor side) has a left-hand thread. After removing the nut, the shaft can be carefully extracted from the compressor wheel using gentle taps (with a rubber hammer).
For the repair, the entire hull assembly was replaced. The new part was already fully assembled and balanced.
Kevin.
Translated on 07-08-2026, 19:01.
Profile PM
Post31-10-2018, 21:03    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
No problem, go ahead and send the pictures over...
Translated on 07-08-2026, 19:03.
Post31-10-2018, 22:09    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Hello Rainer.
OK, thank you.
Attached are the pictures.
 Laufzeug (Altteil) demontiert ohne Rumpfgruppe zur Ursachenfindung des Geräuschs
 File size:  2.95 MB
 Viewed:  1623 times
 Rumpfgruppe GT1749VA (Altteil, nach Ausbau) turbinenseitig
 File size:  2.91 MB
 Viewed:  1558 times
 Rumpfgruppe GT1749VA (Altteil, nach Ausbau) verdichterseitig
 File size:  2.96 MB
 Viewed:  1531 times
Profile PM
Post01-11-2018, 10:07    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Thank you. Please respect copyright. Are the remaining images really yours?
Post01-11-2018, 19:18    Subject: Turbocharger Repair 1.9 TDI ASZ Quote
Hello Rainer.
Thank you as well!
The last image (GT1749VA_mit_Detail_Rumpfgruppe.jpg) is not mine. I only created it by combining two images.
I noted the source in square brackets... [Source: KS-Turbo, 10/2018] ... or something similar.
However, in principle, you can also find these images online, even if they infringe on copyright.
Kevin.
Translated on 07-08-2026, 19:04.
Profile PM
Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Community Blogs, Personal Websites
