Door Seal: How to Install & Prevent Drafts
vag-driver
Post21-01-2019, 13:46    Subject: Door Seal: How to Install & Prevent Drafts Quote
The text describes a Polo 6N. Under the door panel, a foam insert is installed as a water and vapor barrier.
What type of adhesive, tape, or cartridge adhesive is recommended for mounting, allowing the component to be removed if necessary?
Andreas
Translated on 06-10-2026, 2:13.
Karma: +645 / -0   Thank you, like it!
dieselschrauber likes this.
Post21-01-2019, 14:26    Subject: Door Seal: How to Install & Prevent Drafts Quote
There's nothing that can adhere to metal and this type of material on one side and also be completely removable without causing any damage, so I use spray adhesive.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post21-01-2019, 22:03    Subject: Door Seal: How to Install & Prevent Drafts Quote
Hello!
I recommend Butyl.
Hi brezelmann01,
Translated on 06-10-2026, 2:14.
vag-driver
Post22-01-2019, 13:17    Subject: Door Seal: How to Install & Prevent Drafts Quote
brezelmann01 wrote:
I recommend Butyl.
Should it be in a tube or a cartridge? I found this one in a cartridge: Sika Lastomer 710.
Andreas
brezelmann01
dieselschrauber and vag-driver likes this.
Post22-01-2019, 13:36    Subject: Door Seal: How to Install & Prevent Drafts Quote
As a string. The cartridge might even need to be heated. The string is great to work with.
vag-driver
Post24-01-2019, 13:15    Subject: Door Seal: How to Install & Prevent Drafts Quote
Okay, thanks. I'm still waiting for the butyl cord to be delivered. I'll let you know when it arrives.
Andreas
Translated on 06-10-2026, 2:15.
vag-driver
brezelmann01 likes this.
Post27-01-2019, 18:33    Subject: Door Seal: How to Install & Prevent Drafts Quote
It's really easy to do with the string. Thank you for the tip.
Andreas
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Screenshot unter Windows erstellen und posten General Tips
No new posts Window Tint Film: Which One to Choose? Transmission, Chassis, Body & Interior
No new posts Rear Door Panel Passat 3B Transmission, Chassis, Body & Interior
No new posts VW Passat Brake Pad Replacement & Door Panel Removal Transmission, Chassis, Body & Interior
No new posts Intercooler stuck? Diesel Engine Technology
